New 2024 Yukon - long term rust prevention and rubber conditioning
torch
My 2009 Tahoe died of rust here in New England.
I'm just taking delivery of a new 2024 Yukon, and I'm wondering what on the under-body to paint/cover/grease/silicone to minimize repair headaches 10 - 15 years out.
I'm thinking of painting bare metal, steel cooling lines, parts of the exhaust
Spray Silicone on rubber CV bellows, a-arm bushings, .....
lumps of grease on brake bleeders, any nuts that might need to come off in the future, spare tire mechanisms, and slight grease around wheel lugs and hubs.
paint or dielectric grease on exposed ground connections
B-train
Just get some fluid film, or woolwax, (both available on Amazon). 1 to 2 gallons will do the whole truck. Buy the professional application gun with different nozzles ans hoses to reach rockers, doors, fenders, etc. Set aside a whole day if this is your first rodeo to scope out the correct access points.
I generally look for weep holes that allow easy passage, or remove body plugs as needed to gain access. If you take your time, warm up the fluid film in a pan on the stove so it's like thin oil, you will get a nice coating on your vehicle and self....
Once coated, you'll want to touch up yearly on areas that have washed off from washing or road spray. BYPASS the automatic washes and undercarriage washes at all costs - they usually spray salt water in areas it would never get to.
There are a lot of good threads here on this, just search some key words. I've done this process for over 10 years on numerous vehicles with excellent success. When I sell them after many miles of midwest driving, they still look almost new and don't have any body or frame rust. Any paint or rubberized coating will give the guise of protection, but ultimately fail and it won't be noticeable at first.
TCOLL5830
Why would car washes spray salt water anywhere in their process ?
B-train
If they are required to recycle a portion of the water used. It's in that. Salt doesn't settle out like sand or other solids. You then get recycled rinse water blown up under your vehicle that most likely has dissolved salt and other corrosive road chemicals in it.
JayceeP
I live in Nova Scotia…. Both of the major dealer groups in Halifax offer a 10-year rustproofing and undercoating product. I had it on my Toyota 4Runner since new… owned the truck for 11 years and just sold it. The buyers were very pleased with the condition of it. Just took delivery of our factory ordered 2024 XL SLT a few weeks ago and had it undercoated and rust proofed with this dealer’s 10-year guaranteed product before I drove it off the lot. No annual touchups needed on the undercarriage.
Worth the $1000 in my opinion and the all black undercoating looks good too. While all the door panels on the Yukon are Aluminium, the undercarriage isn't, and inside the doors would still have components that can corrode.
B-train
I'd be curuis what they use. Maybe it's similar to the old zeebart formula that sticks around forever and never really dries out.
JayceeP
I touched it yesterday and was slightly damp if that makes any sense lol
E_S_D
I purchased a new vehicle in 1983 that had optional rustproofing applied at the dealership and it came with a "lifetime rust through warranty". I had a spot that rusted through and they denied coverage because "we couldn't get the rustproofing to that spot". So basically, the car was warrantied against rust through, unless it rusted through. All they had to do is claim was they couldn't get to that spot to deny coverage.
B-train
Those sons of B's....
DaveL
Never thought about that. Really good point.
justchecking
Military
SW Ohio
Daughters Escape was ziebarted. They sprayed the outside of the frame with the black coating, not the inside. Drilled holes for plugs in the body cavities but DID NOT spray the oil product into the holes above the rear wheel wells. Once rust started I figured it out and sprayed Fluid Film in there which stopped the rust but the damage was done. I think the best rust proofing at the moment with the corrosion protection the factory already does (maybe) is Krown Oil.
B-train
It sounds like they did a half-asser job then. Why put access holes into to not use them? I utilize any access point I can and coat it with fluid film, or equivalent. Seems to work great. Salt and rust never sleep, you really have to try and beat it from the smallest, hardest, spots to reach.
BacDoc
Vero Beach Florida
Truer words have never been spoken!
Rust and salt never sleep - Niel Young even made millions of dollars on the topic lol!
If I lived in an area with salt for road maintenance, I would do what the Navy does and heavily coat the underside with a mix of oil/grease for anything exposed to the elements.
BadDaddy2003
