P0430 code and coolant temp sensor
TexasPPV
Seems like a common issue here.
P0430 code low efficiency cat bank 2.
Also, sometimes the coolant temp sensor gets “stuck” and the fan runs full blast. I would say this sensor gets stuck 1/20 times on startup, but when it does it’ll do it a few times in a row.
I have seen that sometimes a faulty coolant sensor can cause this code.
I am replacing the coolant housing/sensor this Saturday. Hoping this will fix the issue.
If this does not work- what’s next? Go ahead and replace all 4 oxygen sensors? New cat? Check for exhaust leak? I’ve even seen people say broken bolts on the exhaust can cause this code.
I know my way around a toolbox and electrical systems, but my knowledge on drivetrain and efficiently systems is limited to what I have read on this form.
Thank you in advance for your time and help, I hope this finds you well.
T
TexasPPV
Edit: 191,000 miles. Bought it at 172,000 from the state of Texas. Previously was a state trooper car.
Runs great, occasionally get vibrations on idle at a stoplight.
Jeadding
I currently am dealing with the p0430, see my post. I’ve had issues with my fan staying on over the years and replaced the temp sensor, this last time I changed the temp sensor and thermostat. A little while later I went on a road trip and the car was getting really hot. I swapped out the Autozone thermostat for O’reilly thermostat in their parking lot on my trip. It’s been good for a few months now, but still have the p0430 code I’m researching. I didn’t use any sealant, it didn’t require any.
Andylbc
