08 Tahoe Border Patrol. I want to add dual batteries but the washer tank and a bus box is in the way.
ValleyTahoe
So I see most peoples PPV came with dual batteries. I've been cleaning up the wiring and removing all cut ends, then retaping the loom. I thought to add an extra battery. My first battery is on passenger side near the cowl. Runs to the junction on the fire wall, goes to fuse box on drivers side, alternator and starter. I have a junction box of some sort in the second battery tray on the drivers side. Most fuses are removed but I'm going to check each for voltage while running.
I feel I can remove the wiring successfully but where is everyone putting the washer tank?
Sparksalot
Bastrop County, Texas
View attachment 423697View attachment 423698
The oem tank projects too far down if the border patrol cut was done on the front bumper. That fuse panel was added by the upfitter, so likely can be removed.
Drewphil
