Heated Seats not working?
p1zaul
I've read about every post about the heated seats but can't figure out if mine are possibly not working or it is normal for them to not really get warm. I really don't notice them getting warm at all but the heated seat lights come on and stay on. Can someone confirm I should be able to feel then warm up as I've read a bunch of complaints that when working properly they barely warm up.
Also if the fuse was blown or the element burnt out would there light still come on?
steiny93
if they are working you will definitely feel them
the earlier vintage got warmer
I had a ram with a broken element; the light would light but the element wouldn't warm up; i'd assume the gm seat heaters could fail in the same way
^^^^^x2^^^^^ You WILL feel them. I turn mine on at start-up, and within 5 minutes of driving, I suddenly realize that my a** is on fire, and I have to turn the heat setting down.
B-train
I would agree. The only issue I have currently is a rear seat that tries to warm ip and then cycles off after about 30 seconds. My guess is it's a failed element, but since I don't sit back there I don't really care.
I know my 2008 Denali seats will roast my butt, my 2017 is more subdued, but you should be able to feel them quite quickly.
tagexpcom
I recently purchased a 2021 Yukon Denali - and the 'heated seat' light would either go from 3 lights to 2 OR turn to cold. Part of this appears to be automatic seat warm/cool based on thermostat settings in the car - e.g. with AC set to auto it would turn on seat cooling regardless of manually selecting seat heating or the overall climate temp setting.
So perhaps you have settings issue like my situation? On the 3 lights to 2 - this seems to happen after a few mins regardless.
But yes, when heat is on I can feel it :)
P
p1zaul
So sounds like element is burnt is that an easy test or fix
Tahoe14
Central Fl
What year is your vehicle, there were complaints from early model years and if I recall the fix was replacing the heating element in the seat. There should be a YouTube showing how to replace them, the bottom cushion cover has to be removed. I would do only one first and see if it fixes your problem. Google is your friend. Good luck.
P
p1zaul
Thanks I'll take a look and try it out
BlaineBug
Clown World
I inspected a 2016 Yukon Denali the other week where the customer's complaint was a driver's side seat heater non-functional. When the technician used his infrared thermometer, we noted that actually, BOTH of the front seat bottom cushion heaters were inoperative - but the backrest heaters were working.
justbabs
How do you test the heating element? I have the seat back off, and can't find the wire for the heating element. Searching Google hasn't yielded the results I need. Searching this forum has been even less fruitful. TIA.
P
p1zaul
I haven't messed with mine but it seems easier to just replace it and see what happens.
Thrust
ICT
That's interesting results. When I replaced the bottom seat cushion on my 2015 Denali I noticed the wires going to the object alert actuators in the side seat cushions were severed. They had been pinched from sliding in and out of the seat to the point that the wires severed. The actual seat heat/cool element wires I think gets pinched as the seat foam starts to deteriorate. The wires come in from the back and the pad then sits in several cutouts on the foam. The Seat Shop has a good video explaining it as you have to modify their SLE foam to make it work for heated and cooled seats. My seat does warm better (still not as fast as my CT6 or F150) now that my seat foam is replaced.
BlaineBug
Clown World
Interesting observation. This same customer's complaint I remember was that the seat vibrator/haptic motor in the driver's seat wasn't functioning. I believe there was also a message on the DIC. Maybe that was the problem? Weird though that both front seat bottom heaters weren't functioning though.
My 2019 Yukon's seat heaters work great, even though I read a lot of complaints posted here and on gm-trucks.com stating that the newer models don't get as hot as the older models. I can't tell although I never owned an older model to compare them to.
Taetor
This is what is wrong with my 2016 yukon xl Denali. @BlaineBug was replacing the heating element the fix? My rear seats also do not work. Is there an element for each seat?
there is a top (seat back) and bottom (seat bottom) element and as already noted in this thread if you have the seat vibrators the wires on those tend to break and this can cause a warning on the cluster to show up. might be advisable to inspect those while you are in there the left side is more prone to breaking from getting in and out of the seat.
dhutch89
What was the fix? I'm having a similar issue on my 2016 LTZ
BadDaddy2003
