My hefty lighting investment - worth it - Alpharex and Diode Dynamics
intheburbs
SE MI
Did a bunch of research on headlight and foglight options, and settled on the "buy once, cry once" philosophy. I cried. A lot. o_O
Settled on the Alpharex NOVA series LED projector headlights. Click here
And went with the Diode Dynamics SS3 Max LED fog lights. Click here
I wanted quality lights, good cutoffs (too many people driving poor quality stuff and blinding people), and a ton of light. Yes, I just spent $1600 on lighting.
Install went easy (besides the usual GM asshattery of having to rip apart the entire front end) - headlights were plug and play, but they did take a little finagling to get tight gaps with the fenders. The foglights came with all the necessary adapters to make them plug and play as well, and you simply re-use the 6 button clips holding on the OEM fog housings.
One final mod will be adding the 6-light module, so the fogs stay on when the brights are activated.
First impressions....
Headlight cutoff is super-sharp. A buddy riding with me joked that I can use the cutoffs as an aiming reticle if I ever add James Bond-style machine guns up front. A little more narrow of a throw than I'd like. But super-smooth light distribution with zero hot or cold spots. I give them a 9/10, only because I'd like them a little wider of a beam.
Foglights are stupid-bright with a ridiculously-wide throw. You can't overstate how much they light up the periphery. This is great for me because we live in an area heavy with deer. I joke with a buddy that I'm going to start stenciling his Tundra because he's struck 14 deer. Just a ton of light, all where it needs to go. Now, my only complaint is the the foglights are manual - I have to turn them on every time I get in. The 6-hi mod will help somewhat. On a scale of 1-10, I give them a 15. Seriously.
On with some pics....
Before pic:
During pic:
After pic:
Headlight cutoff
Closer
Fog cutoff
Closer
Headlights only (notice reflective barrier)
Fogs only
Headlights and fogs
Lows and Highs, no fogs
Geotrash
Dave
Richmond, VA
Before pic:
During pic:
After pic:
Headlight cutoff
Closer
Fog cutoff
Closer
Fogs only
Headlights and fogs
As I scrolled through your pictures I kept expecting the barrier to burst into flames. They look great!
adventurenali92
Big Bear Lake, ca
So much light output! That’s awesome! I really like those alpahrex headlights. Wish they made those but for my 2006 because they look so sharp! Definitely worth the price tag!
Trey Hardy
Dang man they’re bright! I just replaced my fog lights where a bulb went out but after reading this I’m kinda regretting not spending some more to get the morimoto projector fogs or a set of the diode dynamics fogs like you got.
992dr
Eastern N.C.
That'll definitely get you down the road, that is an extreme amount of output.
Those Diodes WOW, the amount of light they are throwing is impressive. And I like how they mount in the factory location with no mods.
I think I might have to look into them.
intheburbs
intheburbs
SE MI
One last mod - got the Fleece All Lights On module. Fogs stay on with the hi-beams, or if off are turned on with hi-beams...
j91z28d1
looks nice.. I'll have to check this all lights on module. I put diodes in line with my bi-led so they come on in high when the brights are on. but like you said I gotta manually turn the fogs on every time I start the truck. it's only one button but be nice not to have to.
intheburbs
intheburbs
SE MI
@intheburbs so almost a year later what is your impression now? Still worth the investment?
Short answer? Yes
Long answer: The SS3 fogs are amazing and stupid-bright.
The Alpharex are good, but the low-beam light pattern is a little too narrow for my taste. Maybe it's a government regulation thing, I don't know. High beams are great.
If I had to do it again, I might do some more research and look at other headlights. But I still might end up choosing the Alpharex.
On a scale of 1-10 - performance:
Alpharex lows: 8
Alpharex highs: 10
SS3 fogs: 15
So taken together as a package, I feel I got my money's worth.
If I'd just done the Alpharex alone, I'd probably feel like I overpaid. I'd say the Alpharex would be a good buy at $700-$800.
Fosscore
@intheburbs
Great review. Thx for sharing that feedback on both light setups.
Mostly positive feedback, save the $$ tag for the headlights. Narrow pattern probably good for suburban/city use, but still $$.
Thx man.
Coolman1987us
Maine
Short answer? Yes
Alpharex lows: 8
Alpharex highs: 10
SS3 fogs: 15
Nice thanks for your input. I was looking at the cheaper alpharex projector low halogen high set. I think they were around $400. Definitely going with the ss3s. Thanks for spending your money for the betterment of the Tahoe Yukon family lol.
petethepug
Michael
SoCal
I missed your Orig posting of the install on these. Nice! You’ve earned the respect of my retinas.
Did the lamps come as a complete bolt in assembly or did you have to graft them into the existing housings?
Color is amazing and yes, laser fine optics and cut off. Those are the kind of features that’ll save someone’s life with you getting an extra seconds jump on slowing down or swerving.
intheburbs
intheburbs
SE MI
The headlights were the complete housings. Plug-n-play replacements. They took a little messaging and patience to get them to seat properly with no gaps. As you saw in the pics, I didn't mess around - I did it the right way and ripped off the whole front end.
petethepug
Michael
SoCal
This Gen’s Yukon headlamps really stink. Even the aftermarket options with projector lamps don’t cut it unless you graft in hid bulbs.
You licked the weak link on that platform and gave it a 3x plus up for OEM looks, performance and safety. Enjoy the ride.
blackelky
Im finishing up a retrofit on stock headlights. I'll finish it eventually. Those look good tho compared to the cheaper pro ones they have.
calsdad
I have a 2010 Yukon XL 2500 - and I installed the Morimoto XB LED headlights into it a couple of years ago -and I think they were definitely worth the money. WAY more output than the factory lights, really good beam pattern, and they look good too.
I had installed the Morimoto projector LED foglights into the truck years ago, and while they are definitely better than the factory fogs (as I remember they were horrible), they're still not as good as the Diode Dynamics fogs that @intheburbs installed on his Suburban.
I've been looking at options for upgrading my fogs again. Just watched a video last night comparing a bunch of options and was thinking the Morimoto 4Banger LEDs were top of my list, but I'll have to take another look at those Diode Dynamics too.
Another upgrade that I thought was REALLY worth the money - was replacing the reverse light bulbs with a pair of LED bulbs from Diode Dynamics. I can't remember which ones they were - but those things are AWESOME compared to the originals. They're like headlights on the rear of the truck.
petethepug
Michael
SoCal
Subscribed as the Pineapple Express sounds like it’s going to break my windows with hail this very moment.
intheburbs
intheburbs
SE MI
Bumping this... Found a deal online for the Alpharex - $877. I know nothing about the vendor. Seems to be a company out of Georgia.
mudrunnerz
