Bleeping QD lines to evap / fuel system
Matthew Jeschke
Sahuarita, Arizona
I've done some work to my Evap system. Truck occasionally wreaks of fuel though so I'm back into it. I've replaced everything except the lines (I think are good) and canister. I just pulled the canister to test it.
All besides the point, these :mad::893Chainsaw-Smilie-:banghead::banghead::banghead::banghead: EVAP QUICK DISCONNECTS. I HATE THEM. They ALWAYS break. I've several evap lines with broken QD locks on them.
Has anybody changed these out somehow with something else. They bleeping lines are too short to fit a QD tool on there and so resort to screwdrivers and mechanical hocus pocus to get the bleeping things off and they always break.
Anybody know how to work with them? Replace them? Etc?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I dropped the tank a little while ago and put a new pump then, cleaned and restored what I could.
However, yeah, I should feel up there on top where pump goes in. Good point. It only smells when it's running though.
I felt everywhere else but top of the tank.
What do you do about the lines that have broken QDs on them? They seem to hold on fine w/o them but... no peace of mind.
rockola1971
Indiana (formerly IL)
Are you talking about vent or vapor return lines? I would replace any broken QD's, especially pressurized fuel lines.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
All fuel lines are good. The evap crap just crumbled in the hand though *sigh*. The lines are perfect but the QD's are shot. Can you buy just the QD ends for the evap lines? I was going to pickup all lines at junkyard. They're a bloody fortune new :( I'd delete the evap system before I put new lines on. It'd be several hundred bucks. At least when I last checked RockAuto.
The first is the vent for the evap canister. One of the tabs broke off the QD. The other is still there.
The second is a complete nipple on the evap canister it broke off in the QD. I need to get another canister now. (I think I will just pull a couple at junkyard and test them).
Lastly, the big line from the tank? The QD complete came off trying to remove the canister to test it. UG.
Dorman makes a selection of fuel line quick connects in different sizes and orientations, but I'm not sure if they work on evap lines. Might look up a few and give them a try.
For example:
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I will have to get some of those and try them out. I would be awesome if a screw on type could be retrofit. I hat QD stuff. Except for on the fuel rail where it seems to work nicely cause you can fit a QD tool.
I'm curious, can the evap system cause the truck's fuel mileage to suffer? I assume if the tank doesn't seal right the pump won't work quite right? I'm getting 1 to 2 MPG less right now.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Interesting experience. I went to the junkyard, pulled all the evaporative lines and looked for another evap. Only found one and it was broken same way as mine. I spoke with one of the junkyard dudes that super smart with this stuff. He told me how to fix mine and they gave me the old evap lines I pulled to fiddle with and fix.
I took the broken off fitting from the canister... reinforced it with a straw on inside diameter, glued it together with super glue on inside, then JB weld on outside. He said to then take string and reinforce the outside diameter where crack / JB weld was placed before JB weld sets up. I did that and it setup solid as a rock. If necessary I was going to clean the inside diameter with a drill bit but it didn't clog during glue process.
Then he said to take the evap lines, get the replacement Quick disconnect fittings... Heat the old hose by the fittings with a blow dryer (or heat gun) and it will expand... the old QD fittings come right out and new ones slight right in.
I have it in my head to buy a 3D printer. I'd almost like to redesign this evap canister so it has better fittings (or at least enough space for QD tool) and can swap carbon media out of it / clean it. I'm considering a small business redesigning parts and printing them or having them injection molded for our trucks. At least that's what I spend my time studying on YouTube these days.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I took apart the Vent hose. VERY easy with a heat gun. I'm trying to spec out quick connect fittings though. I notice if I buy on eBay they are literally a fraction the cost of parts store doorman.
I think the vent hose is a 5/8" SAE right angle QC. Not exactly sure if I spec right though? Anybody know??
DETAILS:
Male (hose side) 16mm OD 90degree to Female (canister side) 16mm ID
I think these are the size? https://www.ebay.com/itm/174221824731
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Ah hell... I went to reinstall everything and despite thinking I glued that nipple on well it broke off again. I also filled my tank up with gas and got the WORST mileage since I bought the truck (I've logged every tank) just under 12MPG.
I'm not sure what's up. Super annoying. After I filled it up I felt the tank around sending unit, nothing. Nothing around evaporative lines or canister either. No engine codes and no gas smell. No clue why I'm getting such horrific mileage. But it does have a gas smell sometimes.
Meathead16
Following.
I too had to replace my charcoal canistet because of that #$%m nipple breaking off. I swear everything I touch on this truck that's plastic just crumbles in my hands. I'm convinced she was left sitting somewhere in the desert to bake in the sun for a couple years unprotected. Gotta love AZ. I digress though...
Have you checked out the fuel filler hose? I have this issue where when I'm filling the tank the smell of gas is horrendous, it's as if I'm pumping it straight onto the ground. I haven't looked into it too much yet but I feel like the filler tube/cap base flap assembly is to blame. Sometimes gas will even leak out onto the gas cap area. Once in s great while ill smell gss while driving, but almost akways smell it upon startup...
How's your fuel pressure regulator? If you pull the vacuum line off of it and smell it and if it smells like gas it needs replacing as gas shouldn't be crossing the diaphragm. If the vacuum line has a leak, or the fitting is cracked, it could be letting out the gas smell. That was at least part of the problem on mine. When I first touched them t'o check them, they all crumbled in my hand. I used a small section of ¼ pcv hose or something, I forget, it was thick like rad hoses and fit real snug over the nipples on the intake and fpr, put smaller hose over the plastc tubing that fit snug a decent length, then the larger tubing snug on to that. Sealed it up good.
Still figuring out the rest of the issue though
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@Meathead16 thanks! Yeah I cry when I realize the Chassis & drivetrain on these GMT800s is KILLER awesome but the rest of the truck is a heaping pile of pure crap. It's been an uphill battle keeping from disentigrating since I bought it. However, that said, I bought mine in Rio Rico by AZ Mexico Border and guy literally parked it next to the SUN outside.
My issue is similar, I occasionally smell gas on start-up. My guess has been it's because I'm in open loop with PCM fuel controller. However, sometimes it's REALLY strong almost like I poured a tinge of gas on the ground. I don't ever smell it while driving though thank god. Sorry to hear that.
What year is your truck? Sad thing is I have a 2001 and they seem to have changed the evap canister design shortly after 2001. Long story short, the short run / evap design on my truck cost a bloody fortune to replace versus like $50 for the newer design :( So I really do want to fix the canister. I don't think they really go bad unless you get them wet or completely soaked with fuel.
What I've done so far:
- Evap lines, need rebuilt, all Quick Connects are busted up.
- Fuel filler - it's good, no issues. Simple ring clamp connection, easy enough to adjust / fix if necessary.
- Fuel Pump & Tank - I replaced entire fuel sending unit. When tank was down I cleaned and inspected it. Tank is a quality piece and still like new, along with all connections on top. I've since doubly inspected, by feeling top of tank and everything is in perfect order on top of tank.
- Fuel injectors - Completely took apart rail, cleaned and visual inspection (I have a built up 6.0L) I swapped with the E85 injectors I don't recall what that engine is called. One thing I never did was check fuel pressure / the regulator. I had ordered a fuel pressure gauge and company sent me the wrong thing long story... but I definately need to check fuel pressure. Otherwise, I've tuned the fuel for new build and it's spot on w/ Wideband O2 and narrowband.
- Fuel regulator - the vacuum line was broken when I did my injectors. I need to do the smell test! That's a great idea. I have since installed a new vacuum line.
- Evap canister - damn thing. I could scream, yeah the nipple (male fitting) for tank line broke clean off. I glued it back but no luck. I need to order a male fitting of that size, then cut them at a point where there's some extra before the lip for QC lock... then take a slightly larger diameter hose of some kind and just glue the two together with JB weld. I may actually reinforce all the fittings on the evap like that. Then get some quality quick disconnects. The ones from the factory, and upon further inspection, doorman is same style, are complete CRAP. If you are lucky you can get screwdriver to unlock them (QC tool doesn't fit). And the finger release design doesn't work. The lines themselves are great quality otherwise.
Eldiablo
Spray with wd40 to get any grit outta there and lube the oring seal. Feel on top of your tank. Is it wet with fuel? Sure you dont have a leaking fuel pump module oring seal? Or rotted out retainer for fuel pump module?
Make yourself a smoke machine makes this kind of repair much easier.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Back to messing with this cheap junk fuel and evap line stuff from GM. Saga continues... I bought a new evap canister. Mine isn't doing anything, garage just smells like fumes when I park it. I assume cause carbon is spent up after 23 years.
Turns out the tank and purge fittings on my current canister are 3/8" fittings. The new canister I bought is 3/8" for tank, 1/4" for purge so new canister won't fit. I'm looking for another canister with 3/8" and 1/4" but cannot find one.
Anybody know how to change the purge line by the vapor canister? I cannot find a part number for it or anything.
Old canister 3/8" purge fitting
New canister 1/4" purge fitting
I thought maybe I could just glue some straws around the fitting to increase the OD. However, the stupid lip to catch the QD is 3/8" when old one is 7/8" so the clips won't even engage on it.
Second question, I cannot figure this one out. I took a road trip to higher altitude. It is as though the tank is not purging and or venting. Purge valve is new, tested and works. The vent is new, tested and works. The vent hose is rebuilt tested and works as well as the tank evap lines. The tank pressure sensor is tested and new (I read the reading with a scan tool). I can command purge on and off with scan tool and the tank pressure changes / registers on the pressure sensor as read by the PCM. Oh and the vapor canister flows freely.
However, the tank swells and when I take the cap off it vents out the cap. This makes no sense to me. I'd think it would vent out the vent line and or the engine / purge line would take the exess pressure?
Video of problem...
When the ignition is off, the vapors vent from the canister out through the vent valve in the rear. Either the valve isn't opening when the ignition is off, or the canister or line is plugged.
RockAuto shows several evap canisters for your '01, and all of them have three different size connections. Are you sure your new canister is the correct one for your Tahoe?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Turns out I'm "stupid". I forgot I rebuilt the purge fitting on canister. When I did that I made it larger so as to be able to glue a nipple over the top of the old one. One of the VERY few times my junkyard lute (personal junk pile) came in handy. Turns out I had another set of tank vapor lines w/ the correct QD. I just recycled that.
I also discovered in the process I'd mixed up the purge and tank evap ports. They were reversed. Not sure if that was causing fault where tank doesn't fully depressurize.
The vent valve is opening as expected. When truck is off I can literally see (when I look under truck) and hear tank venting through the vent valve. Hopefully I'll no longer be able to "see" the vapor under the truck with new purge valve. Nor smell it.
Thanks for help! I've gone bananas tinkering with this evap stuff. It's VERY poor quality fittings and lines from factory. I suppose they're "good enough" but not that fun to work with. That said I'm getting too good at it. Only took about 30 minutes to get the line off the tank and didn't even have to take the tank off :)
I wouldn't call it "stupid," just experimenting!
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Haha thanks!
Anybody know where to buy a tool that fits the test port on the evap system (under hood by fuel rail)
Also I assume the tank should hold pressure till vent or purge is opened?
Towmaster
