2011 Yukon XL LT - Overland Build - Input Appreciated
osb40000
Helping my buddy build out his 2011 Yukon XL LT and doing all the research for him since he works 80hrs a week and has a wife and kids. I'm new to this whole GM arena but have been reading up on here as much as possible. Looking for input from those who have done similar and have learned what works and what doesn't.
He's not looking to do hard core rock crawling, but does want a decent ride and more ground clearance than he currently has. He has a wife and four kids and his boys are huge so between people and gear it'll be loaded heavy, my guess would be 900-1000lbs in people and then another 150-200lbs in gear. I wouldn't say this is a budget build at all, he's looking to go with coils instead of spacers.
Right now the only thing that he has set in stone is running LT285/75R17 Toyo AT3s. They balance easily, do well in the snow and measure in right at 33.9" and weigh 60lbs in E range. Should work well for his long 600+ mile trips in the south west. He's willing to trim so fitment shouldn't be a problem based off what I've seen in here.
Looking for suggestions on:
Wheels:
Doesn't want them to stick out a bunch and make fitting them harder but also enough to clear the UCA, frame, etc. Thinking 17x8 or 17x8.5 but not sure on the perfect backspacing. Would love something lightweight to cut down on rotating and unsprung mass but I don't think he'd spring for forged stuff.
Suspension: Looking at the Cognito 3" they're using 2" Fox IFP Coilovers and then slapping a spacer on top. Anyone have a link for just the spacer? I don't see a way to get just that from Cognito or just the Front Fox setup with the spacer in a standalone.
For the rear, I'm guessing the Dobinson's C09-037 660-880lb constant load springs will be best (he doesn't want sag and he will tow a popup trailer here and there). Not sure what rear shocks to pair with those Dobinson springs. I'm also open to running something completely different than the Fox and Dobinson combo if it makes sense.
UCA: Open to input here. I and friends use ICON, SPC and JBA UCAs on Toyotas. No clue what to look at on GM stuff.
Axles: Not sure on what gearing he has or how to find out, need to look into that. Hoping it's at least 3.73. How do these rear ends hold up to tight limited slips with bigger tires? I don't think he's interested in doing a locker, but maybe.
I'll make him some rock sliders when I build mine. We'll use a mix of 2"x2" 3/16" tubing and 1.75" .120
What does he need to do to keep his trans happy? Are you guys running a big aftermarket trans cooler? If so what are you using and how's it working out?
What else should we be looking at? I don't know what I don't know and appreciate guidance from more knowledgeable people.
B-train
Wow! He's watched a lot of videos about it and caught the bug. LOL. Been there too.
My input won't be what you are looking for because I wanted as close to OEM as possible for ease of service and repair. I did 18" GM aftermarket wheels with Nitto Terra Grappler G3 tires - 265/65/18. They handled everything the CO, NM, and WY roads and passes had to offer
A few questions about gear. You said maybe 150-200lbs. I would ask are they just doing day trips? In order to REALLY get out there, you are talking a good 12v fridge, pots/pans, food, extra fuel, extra identical spare tire, extra water for food, water for cleaning, tools for recovery and repairs, extra vital fluids, etc........Then sleeping? Ground tents or RTT (which weigh 150lbs, require a good rack and air deflector).
Is he set on his ideas, or can there be wiggle room to use as a good base and then grow from there? If so, then maybe upgraded springs, good tires, etc. Also, if it has the air shocks, then maybe stiffer springs with those as an asset would work quite well.
Just my thoughts. Happy to help how I can. Overlanding is fun!!!
O
osb40000
Thanks for the reply! He just bought his wife a 2019 Suburban so the 2011 Yukon XL is going to be their camping/offroad beater. He brought his son on an overnighter where we did around 200 miles on dirt in two days. He was immediately hooked. It helps that we live in a meca for offroading/overlanding and have more trails available to us in a 5hr drive than we'll ever cover in a lifetime. I don't see him being out for longer than 4-5 days at a time and most trips will probably be 2-3 days. I'm the mechanical one that's built a few rigs for myself and buddies but I'm a fish out of water with GM stuff so looking for input on what works.
Good to know that your Terra Grapplers held up on your rig, gives me hope that his AT3s will do fine under such a big pig.
He doesn't have the air-ride adjustable suspension. For the rear the Dobinson springs appear to be as beefy as it gets for off the shelf with a 660-880lb constant load rating over stock in addition to providing 2" of lift. This page shows them handling plenty of weight so I think he'll be good with whatever the throws at them. https://baselineoverland.com/blogs/suburban-builds/baseline-overlands-gmc-yukon-xl-denali-walkaround
Won't be running a RTT, there are six of them so just a basic ground tent. I don't see him doing a fridge, he has a great cooler that stays cold for longer than he'll ever be out.
Good call on the extra gear, I could of course be off on 150-200lbs and wasn't including a ton of liquids which do weigh a lot, so I probably underestimated a bit. I also didn't factor extra spare tire and tools in that estimate. Anything specific/special you bring for tools that are GM specific?
I appreciate your time!
B-train
Nothing specific in the tool department. The LS motors are pretty easy to work on, as is the remainder of the mechanical stuff.
I bring:
1. Multimeter
2. 8,10,13,15,17,18,19,22mm sockets and wrenches. This covers most stuff under the hood, etc.
3. Hammer, vise grips, pliers assortment, screw drivers, etc.
4. Some spare trans cooler/oil cooler hose and clamps to make a repair if needed
5. Couple gallons of antifreeze concentrate
6. A few qts of oil.
7. (2) 1 gallon jugs of ATF
8. Replacement main belt
9. Misc silicone hose 5/8" & 3/4"
10. Zip ties, tape, silicone, tire kit, and 18v air compressor.
Just the basics that I'm sure you're aware of, plus extras as deemed necessary. My 2 totes of extra supplies and tools probably weigh in at 100lbs, but I'd rather be able to try and limp home vs being stranded.
O
osb40000
I bring:
1. Multimeter
That's an extremely helpful list. Thank you for taking the time to type that out, I'm going to share with my buddy and get him started on getting prepped.
On the zip ties, have you found a specific brand that works well and doesn't break? I've had terrible luck with zipties getting dried out and brittle.
B-train
I get them through work, but the ones from McMaster Carr have been quite decent on projects. It seems a though most supply house have better quality than any big box store. We use OEM mfg ones as well and they are tough as hell.
Edit: it seems as though the ones that have a shiny appearance are more flexible and don't break as easily new, or over time. I've used a lot of Caterpillar and Kohler OEM zip ties over the years and they are almost indestructible. Again, they are a shiny appearance, and a little thicker than the standard cheap ones.
Swanbird11
Trans cooler definitely helped my temps. I think Ive got a Hayden cooler but alot of people run trucool 40k cooler.
I ran AN line from my trans straight to the cooler, bypassing the radiator. My old radiator got a internal crack and mixed trans fluid with coolant... not fun.
ALSO I highly recommend replacing the trash plastic Tee's coming off the heater core. Better yet, get the stainless adapters and barbed tee's. trying to fix those on the trail can be a real pain.
O
osb40000
Love it. This is the kind of first hand knowledge and experience I'm looking for. Is the Trucool 40k beefy enough to run solo without the radiator?
Swanbird11
I would imagine. Its larger than the cooler I run and im still below stock temps.
Charlie207
LFOD, New Hampshire
I bet anything is better than the factory non-K5L aux cooler. Even just getting one of those from a junkyard with it's brackets would be an upgrade.
Bubba6
