Buying 06 Z71 in limp mode because of leak from transmission to transfer case?
keatonmx
I am considering buying this 06' with the issue above. He tells me that it is in limp mode and will only drive to 2nd/3rd gear and he had to flutter the gas and coast. He tells me that Firestone said it is a leak from the transmission to transfer case, and it needs to be sealed. he said adding fluid did not put it out of limp mode. the price is $1500, "my loss your gain" story. Does this seem too risky to buy or should I wait? having a hard time finding anything decent, and the Z71 is nice. Thanks..
strutaeng
Dallas, Texas
Seems like a good deal if overall condition of vehicle is good.
My advice: plan on a transmission rebuild.
You can find GMT800s with blown 4L60e transmissions here all day long being sold for cheap, some in very good shape, but most are average or poor condition.
91RS
GA
Guaranteed that transmission is gone so consider if it’s still worth it to you to replace or rebuild it on top of the cost.
drdave81
Waterford, MI
Go buy a cheap code reader, then go check it out. See what the codes are and google them. That will give you a good idea and maybe be able to negotiate. Though, if the body is clean and the vehicle is in decent shape, $1500 is a good deal. Trans can be rebuilt pretty cheap, and a used one is even cheaper. Labor of remove/install is what will add to it.
91RS
GA
I think of the truck is cosmetically in good shape, the paint hasn’t or isn’t starting to fail (this would be the biggest concern for me) and the interior is clean, $1500 would be a good price and then spend $3k more on a transmission and you’ve got a solid truck. I would worry about buying an older 4L60 at this point so that worry would then be gone. Some mechanical fixes like suspension or leaks would be expected probably on any of these up to 2018 at this point.
mountie
Limp mode..... I'd get a second opinion. A few months ago, my '05 Yukon was in a sort of limp mode, and my dash was showing " Service 4 wheel drive" and a CEL. The next day, I found my battery ground connection was not tight. Fixed....
( I just had my starter replaced, and the battery wasn't reconnected properly)
GMT800 2005 Tahoe Z71
Navy Supporting Member
But, with the truck stuck in LIMP mode, how does he know there isn't an engine problem as well? Fuel pump? Catalytic converter?
If I can't drive it, normally, I better be in a "fix it" mood.
mountie
In Limp Mode..... is the truck just slow, or is there a miss / or stumble / or exhaust smoke, also ?
When my battery ground was not tight, the transmission at a stop sign, started in ( what seemed to be), 2nd. But it ran smoothly.
( remember my last thread, " Changed starter, what can go wrong?"
K
keatonmx
Would be nice to know the CEL codes. Does not sound legit at all. Miles?
I'll have to check the codes. I believe only the transmission is in limp mode and not the engine. I also found a black 03' Z71 5.3l for $5k that is 1 owner, pretty clean but has 180k miles. Worried about having to rebuild the trans, he says it runs good and " New shocks all around, new pulley and tensioner, new serpentine belt, new alternator, new idler arm, new pitmen arm and stearing gear, power stearing fluid change, new sway bar linkages. Recent oil change and trasmission fluid change. Rear Differential was last serviced in 2017. "
Would you pay $5k?
mountie
Would you pay $5k?
A probable, "yes"
K
keatonmx
I also found an 03' z71 5.3l that has 175k miles. He says 1 owner, and looks completely stock. It's out in the country. "New shocks all around, new pulley and tensioner, new serpentine belt, new alternator, new idler arm, new pitmen arm and stearing gear, power stearing fluid change, new sway bar linkages. Recent oil change and trasmission fluid change. Rear Differential was last serviced in 2017. "
Would you pay $5k?
91RS
GA
Would you pay $5k?
I’d really worry about that paint on a black one.
K
keatonmx
The other thing with the Tahoe outlined in my og post is that he wants to meet at the DMV to "make title transfer easier". And that's usually suspicious imo
mountie
get the VIN number.... check it at the dealer... they can pull up the service history and maybe ownership. Before I bought my '05 Yukon XL ( one owner), it was a trade in / I bought it from a friend who goes to auctions. The VIN print out at the dealer was WONDERFUL !!
The seller should be more than happy to give you the VIN... If he hesitates, run away !!
ivin74
05 NBS Nali
Htown, Texas
I would buy it sight unseen and part it out. I can easily double my money.
Towmaster
