Gt4 G65 G80 rear differential
Chev7272
Question for everyone, have a 2001 gmc yukon xl 1500 4x4 SLT . The rear end is locked up . Have the tires off the ground and the tires turn in different directions but the ring gear and pinion gear don't move . I have read that the G80s tend to lock up just wondering if this is the issue ? Any advice would be greatly appreciated. Thanks
strutaeng
Dallas, Texas
Pop the differential cover! What happened? Did you blow up the spider gears? Won't know until you remove the cover...
C
Chev7272
Nope the spider gears are good the turn when I turn the wheels .
C
Chev7272
Not sure what happened . Left work and the driver side tire was acting like the ebrake was on . Not sure on the pass side
C
Chev7272
Removed the cover and spider gears are good and turn with wheels no metal shavings .
RST Dana
OH
Ok. With the vehicle in neutral AND the rear axel is off the ground, will the driveshaft turn?
rockola1971
Indiana (formerly IL)
Im not sure what you mean by "locked up". What does the vehicle do when you try to drive forward? And you're sure that the axle retaining pins are in place?
B-train
It should turn as long as both tires are rotating in the same direction. If you are just spinning one and the spider gears are working, then probably not going to see much.
Try spinning the driveshaft by hand in neutral and see what happens. If that doesn't work, remove the shaft snd try spinning the yoke. You'll either know if it's in the rear end or transmission at that point
C
Chev7272
Driver side tire was locking up yesterday when I drove home from work .
C
Chev7272
Tried the drive shaft and it wouldn't turn . Disconnected the drive shaft and it moved . So did the drive shaft at the transmission
B-train
Do you have a frozen u-joint at the pinion then?
rockola1971
Im not even sure what you are attempting to say here. When "tried the driveshaft" did you have rear wheels off ground and tranny in neutral while turning the driveshaft? Where exactly did you disconnect the driveshaft from? Tranny end or differential end?
C
Chev7272
Yep u-joint on the rear differential was toast . Also my emergency brake pads were toast will thier gone no pad and down to metal . All fixed now .
Durobans
