Losing Coolant
MT Driver
I have been losing about 1/2 a gallon of coolant per week. You can smell it in and outside the vehicle when you stop. I have checked for coolant in oil (no milky dip stick), used a block tester with no change in color, and the trans fluid is clear. No visible leaks anywhere. Going nuts trying to figure where coolant is going! Any other suggestions??
B-train
It's probably weeping from a fitting somewhere and evaporating. Look for white residue around hose ends, radiator areas, waterpump bottom, etc. Also, if in a salt state, look at areas where metal lines go through brackets.
If that fails: Throw flour on it......
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
I assumed you have checked the obvious places at the front and at the tees. How about checking the lines/connections at the back heater?
Geotrash
Dave
Richmond, VA
That's a pretty quick loss, depending on how much you're driving. 3 things I would check:
1/ The radiators on these fail first by weeping through cracks in the plastic end tanks hidden in hard-to-see places. Get a flashlight in there and look real close at everything you can see.
2/ The plastic coolant tees at the firewall crack and weep before they fail. Check for stains and moisture there.
3/ The plastic coolant reservoir cracks and leaks. Loosen it and look at the underside.
Welcome to the Forum from NH.
Pics of the truck, please.
Capybarbro
