Update on cleaning white interior
tjs3922
My main concern on getting my 23 Denali with the light shale was jean dye rubbing off on the seat. Well a month has gone by and some blue dye is creeping onto the seat. I am happy to say that the Lexol leather clean/conditioning kit worked perfectly. So well, I didnt even put the conditioner on this time.
1) put some of step 1 Lexol on provided pad and rub onto the seat (affected areas)
2) use a damp cloth to rub off any excess Lexol (there really wasnt any but I did use the damp cloth anyway)
3) buff with clean dry towel.
4) done (all in about 3-4 minutes for one seat)
adventurenali92
Big Bear Lake, ca
the less you use conditioner the faster your leather surfaces will dry out and crack. It’s skin so it needs moisture retained. When you clean with any kind of cleaner you’re stripping the natural oils off the surface that help it retain moisture. Conditioner should always be applied after a cleaning.
tjs3922
tjs3922
Thanks for the info! I will do that.
Mckennahc
