2023 Tahoe Rear LED bulbs?
mestes1999
Midland, TX
Anyone tried LED rear turn signal bulbs? Any in particular that don't autoflash? Also any recommendations for LED brake and reverse lights?
Blows me away that it's 2023, full LED front lights, but still have incandescent bulbs in the rear.
hkon412
I just purchased a pre-owned 2022 Tahoe Z71 and the previous owner installed LED brake lights. Didn't realize it until I took the vehicle in for service b/c I kept getting a "Check Brake Lamps" message whenever I started it up. The lights work fine, but the service technician told me the computer doesn't recognize the aftermarket bulbs so the "Check Brake Lamps" message is something I'll have to live with if I want the LEDs. It's a bit annoying since I have to click the message away each time I start it up, but I'll deal with it since I prefer the LEDs.
M
mestes1999
Midland, TX
This is even worse than previous cars. Previously you could replace the brake and reverse lights (the ones I want to replace the MOST, they look AWFUL) and it would be no big deal. You would only get a message or hyperflash if you tried to swap out the turn signals.
Now, good lord. This car is too smart and too dumb at the same time.
H1Chester
Check the search function and YouTube. There are a few threads on this. For the most part resistors are required to prevent a code. I haven't done this yet but will be doing it at some point.
Roscoe2352
Figure out what bulb sizes you need. Im looking at getting front turn signals and reverse lights for mine. Get on amazon and check out SEALIGHT once you figure out what sizes you need. Ive been using SEALIGHT bulbs for a few years in my 4 runner as well as friends and family cars as well. HIGHLY recommend. Inexpensive products and they last for a while.
PPK_
Oklahoma City
Yes.. you need to add some ballast resisters.. I think they are 10 ohms.. that will keep the computer satisfied. The leds do look great compared to incandescent.
h0m3w3CkeR
Virginia
Has anyone installed the resistors on the reverse lights? I am having issues installing the 50w 6ohm, installed but still getting the error. I wired them onto both the black wires. I have a feeling that its not right.
jpurdie
