USB Upgrade
jlaspina11
I have a 2019 Tahoe LT and i want to upgrade my USB-A ports to USB-C especially the dual port that is right near the cupholder but eventually all of them. I have been Googling for the preplacement parts but not having much luck. I found an older thread on here with this discussed but it was never followed up
Has anyone done this? If so can you provide part numbers and links?
Here is the main one I want to replace
Thanks in advance
RST Dana
OH
Here is the main one I want to replace View attachment 412350
Thanks in advance
What is the need for USB c there? If it’s only to charge, then Amazon sells USB to USB c adapters.
jlaspina11
jlaspina11
the need is all the cords I have are usb-c. Not just for there i want to swap there and throughout the truck for my kids devices as well
As stated above, the simplest remedy is to buy a number of USB-A to USB-C adapters and plug them into the existing USB-A sockets.
koachdaddy
Space Coast, FL
Thanks in advance
The thought processes used sometimes make me scratch my head. Here's a pair of USB ports mounted vertically and have a cover. Mine (Premier trim) has them mounted at a 45deg angle without a cover and right next to cupholders. My wife and I are pretty careful but...
jlaspina11
jlaspina11
I have the same setup on mine. I just ended up getting plug in converters off of Amazon
PaulB
Thanks in advance
I want to do the same thing with my wife’s GMC Acadia 2019. I’d like to put USB and USB-C like my new Sierra has. What did you ever come up with? Like you, I want to make it look factory, no adapters.
$19 for a grip of 10 and you don't have to tear anything apart, you can adapter any usb to any usb, same with scsi and a host of other interfaces
the only difference is data speed, but if just for charging it doesn't matter.
CKendrick
