2023 Tahoe RST
Metalgirl
Bought my RST in July 2023, after having a 2023 Tahoe LT for almost a year, loved my LT but wanted some of the things the RST had that my LT didn't. Now I am wishing I hadn't. I traveled to another state to purchase my new RST, noticed almost right away that it rode rough, seemed like maybe the tires were not balanced. I took it to Chevy after 500 miles, they checked everything & only performed an alignment & sent me home, Tahoe was still doing the same thing, they told me I needed to drive it to 1500 miles before they could do anything else, so I did. Took it back in, they called & told me it had 2 bad injectors, so both injectors replaced, they also replaced the driver side valve cover because oil was leaking into cylinder 5, which they found when inspected, they also replaced all 4 tires, saying they all had flat spots. Just got it Friday from these repairs but again, it still has the same vibration, as if the tires aren't balanced, that's the best way I know how to describe it.
Anyone know what they are missing? I feel like I am going crazy with this new RST & wish I had not made the change because my other 2023 drove so smooth.
DuraYuk
Maybe find another one to test drive. Perhaps the suspension is firmer than your used too?
DwDrummer
AL
I found this thread as I’m looking to buy a 23 Tahoe RST performance model and I noticed it had the same vibration almost like the rear wheels did not have weights on the wheels. They replaced the tires and this still did not change the vibration
. The performance model uses the Firestone Firehawk pursuit tires which I’m kinda wondering if that may have something to do with it. If anybody can chime in that would be great, can’t spend $80K for a truck that shakes at highway speeds.
DuraYuk
I'd imagine if it's an rst performance edition it's the stiffer suspension and performance tires.
DwDrummer
AL
I think you are misunderstanding what me and Metalgirl are saying about vibration. I know since the truck is a performance model it will have slightly stiffer suspension however, it still does have magnaride. My dad has a 23 Yukon Denali and up until 72mph + his Denali and this Tahoe honestly ride 98% about the same which is smooth and quiet. I can tell on certain rough areas of the road the tahoe does have "slightly" stiffer suspension but stiff suspension and vibration are 2 different things. The only way I can explain it is to imagine if you took the wheel weights off your rear wheels today and went for a drive on the highway at 75mph+ and that's the vibration I'm talking about. It's coming from the rear of the truck and was shaking my leg and shirt, if you put your hand on the door panel it was shaking, almost like being in a massage chair:D It's definitely not normal, if GM is saying this is normal I need to completely quit buying any of their vehicles.
My dad also has a C8 Corvette so tires and suspension are going to be stiffer on that car vs his denali but I feel 0 vibration in that car and it rides and drives smooth.
vcode
How does a valve cover leak oil into the cylinder?
carortruck
Has the dealership looked at the transmission 10sp?
My 23 yukon has same vibration
Does it go away with putting the transmission in 9th, that will turn of dfm and rule out engine
Baja_Bob
Michigan
What rims do you have? The rims may not be true from the factory, causing the vibration. The corvette's had issues with rims being out of round from the factory.
Hrocks
I had the exact problem with one of my previous Tahoes. The dealer owner is a friend of mine and he told his guys to Road force balance the tires. Issue solved. Each tire on your RST weighs about 40-42 pounds, plus the weight of the rim (at least another 20 pounds?). As good as the current tire and wheel manufacturing processes are today, there are tolerances and therefore are not absolutely perfect. A traditional regular balance job is usually good enough for everyday driving vs. competition use. The bigger the tire diameter and lower (stiffer) the sidewall, the worse the ride and the more prone the combination is to magnify the out of balance condition when you get up to highway speeds. Usually when tires are mounted most "technicians" just randomly install it on the rim without any regard to the highest point on the rim (some color dot or marking) and the lightest (yellow dot) and flattest points (red dot) on the tire. A GOOD installer will identify and align the tire appropriately on the rim. Road force balancing introduces a roller that simulates the force working against the tire and identifies the radial and lateral forces when in use and ultimately gives a more exact measurement of how much weight and where exactly it needs to be placed. Press your dealer to road force balance all tires. If you truly have a vibration after that rather than just a stiff ride that just accurately transmits the imperfections on the road, you may then have other problems. (However I would doubt that.)
Shiftgreen
I have a 23 Tahoe RST 4x4, not the 6.2 version. However, it is super smooth to us. We always talk about how much smoother is is than my wifes grand cherokee. I also had an older z71 and by far this is the smoothest vehicle I have ever ridden in. No vibration and I have been up to 85- 90 and still not one issue of rough riding or wheel/tire vibration.
DwDrummer
AL
What shocks do you have? Magnetic or premium smooth ride?
Shiftgreen
Not sure this was directed towards mine, if so I honestly think its smooth? I thought it was magnetic at first bc it was so smooth but from what I understand the 5.3 RST's only have smooth? Hopefully someone could chime in more.
NELLY1947
i know exactly your problem...after 1 set of original tires..3 sets of Michelins... and only 30,000 miles. 3 different dealers spent a total of 40-50 hours over 2 1/2 years on a 2019 yukon denali that had never been hit or even touched a curb or even a big pot hole. 2 front wheel bearings. 3 wheel alignments. and road force balancings i cant count. i said spin the mags with no tires or weights. well 2 of the mags had deviation of one 30 thou and the other had 52 thou. brought them to a wheel shop and 100$ each and the truck is perfect. how/why no one did that, i don't damn know. i have spent somuch time it's nuts. a lot of shops will test your mags with the tire on it.
KMeloney
Yo DW! Long time. Hope you're well. Just got a new '23 Yukon myself. Same color/chrome scheme as my '09.
Anyway, I think (not 100% sure yet) I get a bit of a vibration around 73-78 mph in my Denali-with-air-ride, too. Definitely isn't there before and after that speed range -- so, that suggests to me it's a balancing issue. Different tires on the same wheels might have helped, but I'd say the wheels would need to be rebalanced with the new tires on -- and for high speeds. (Maybe you've done that already though...)
Keep us posted!
DwDrummer
AL
Keep us posted!
What's up, Kirk! Been a long time man, I've been doing good, and I hope the same for you. I ended up passing on the RST Tahoe, the dealership changed tires and that did help out quite a bit however I was still feeling something I couldn't get passed. Also, the front bumper was suffering from GM's paint chipping/peeling issue so I just backed out of it all together. Congrats on your new Denali from your profile picture it looks nice!:)
Conedaddy
