Just installed the “stock” replacement struts by Luft Meister. I also have the 2” rear drop springs (kit) from Maxtrac installed.
I measured from bottom of the wheel to the fender prior to the drop and was at 32.25” in the front. After install of the new struts and springs in front, I noticed the rear had some “squat”. After measuring again, I found approximately 1” of lift in the front (33.25” from bottom of wheel to fender).
I know springs will settle over time, but wondering how I can get the front back down that inch. Anyone have experience with Luft Meister?
I should also note that I’m getting a C0575-1A code (left front) and a “Service Suspension” alert on the dash. I’ve already reached out to Luft Meister about this.
