BCM issues does this include the exterior mirrors?
Chain Saw
I am experiencing the rear door open on the dash but it is closed, I also cannot use rear wipers or washer. Now one of my mirrors will not return to the usable position.
I have ordered a new BCM and a dealership has said they will install it and program it for $150.00. Does anyone know if the BCM is causing my mirror issue?
Could be, you really have to see what the internal trouble codes are.
As stated above, a good bi-directional scanner will help you locate the source of the issue, versus firing the parts cannon.
power mirror is likely a broken gear (which is replaceable, takes about 30 minutes)
rear hatch is probably a sensor in the switch actuator/locking mechanism (also replaceable)
probably wasting money on a BCM, if the dealer told you that was the problem without troubleshooting it then find another dealer.........
a tech2 is your friend.
048tahoe
