Headlights flicker, mirrors won't fold, no turn signal sound
rmatt901
I have a 2015 Yukon and headlights are flickering along with, no turn signal sound and mirrors won't fold in. The battery and alternator are both charging, and reading good voltage. Any suggestions?
B-train
I would go after a bad/corroded ground first. But, ultimately, those are controlled by the BCM I believe. Poor power or a bad ground can freak them out.
Does the flickering change with RPM by chance? Trying to rule out a flakey alternator
wjburken
Eastern Iowa
Might give your post a little more of a descriptive name. Lose is not very descriptive.
As has already been mentioned, check your grounds.
R
rmatt901
I apologize and agree. I'm new in here so, any corrected criticism is appreciated.
Parking sensors aren't working either, no seat belt warning sound. Although I did reset the outside mirrors.
R
rmatt901
It seems to get a little better with at more rpms.
wjburken
Eastern Iowa
No worries.
Did all of this just start out of the blue or did you have some work done or have some incident with the vehicle?
check all your battery cable connections and check you battery as well. These vehicles hate bad grounds and low voltage. How old is your battery?
Are you able to measure the voltage across the battery while it’s running?
This reads like a bad battery connection at first glance. Loose cable, bad ground, corroded cable or a BCM that's on it's way out. Go for the simple stuff first.
Was driving home once and every time I used the turn signal the cruise control kicked out. Turns out the positive battery cable was loose.
R
rmatt901
No worries.
I replaced the rear speaker in the cargo area and that's when all the hazard sounds stopped working but radio works fine. The lights had been flickering a couple weeks before. My mechanic checked alternator and battery yesterday and said everything was charging good.
BlazinMilk
