AC condenser Pusher fan plus 40K transmission cooler
Spaul
Curious if anyone is running both of these? Will be auxiliary Pusher fan still fit?
Alex_M
Pusher fan definitely wouldn't fit in front of my 40k trans cooler.
Would recommend a smaller cooler unless you tow a lot. The 40k cooler keeps my trans cool enough in my 2500 that it doesn't go into lockup all the time. Floats around 110* even in ambient up to 80*.
Great for towing though. Haven't seen higher than 175* or 180* yet with a load.
whyhelloofficer
I made it work --
It ain't pretty, but neither is my Yukon.
I am running the 40k Trans Cooler on the driver's side that I had to scab up some random metal stock from the Big Orange Box Store.
The pusher fan is on the passenger side on a manual switch inside that is set up in the center console. I use it for extended periods of idling and in the Summer here in FL. I will get some pictures for you in a few hours.
Truckinscooby
