cyl 4 misfire
slyhog022056
Back again. Got a cylinder 4 misfire, been trying off anf on to fix it. No luck so far. Have changed all coil packs, plug wires, plugs, I do have spark at cyl 4.No knocking like a stuck lifter. Should I swap a couple of fuel injectors around or is there a way to check the wiring plug for getting a firing command. Where do I go next before tearing off the intake manifold for a stuck lifter. I pretty much stopped driving it because fully floored it takes better than 1/4 mile to get up to 50 and 70 at WOT
Geotrash
Dave
Richmond, VA
Pull the pax side valve cover and crank it over. If the #4 rocker(s) don't move, you've found your problem.
montanaboy65
