Another rough idle and new codes...
05YukonXL
South Carolina
All this leads to P0171, P0174, P0300, P0305...
Background: Have had intermittent P0305 (not AFM cylinder) for 18 months on 2014 LT with 115000 miles but there were no clear cause or noticeable symptoms other than minor bad idle at low rpms (while stopped). Coil good, spark plug good, took off valve cover and everything appeared ok there too, clean oil on every oil change). Very drivable and barely noticable.
Jump to this past December on a cold morning in NC the the truck struggled to turn over with traction, stabilitrac, abs, airbag warnings). Very rough idle at low RPM (almost stalling). Drove home the 300 miles to warmer climates.
Got home. Replaced battery (was not holding charge). Didn't really have the bad symptom again... other than intermittent rough idle at low RPMs. Still not settled, took the truck to mechanic to check and replace spark plugs, replace coil, did a 'tune up', cleaning throttle body.
Next day, same intermittent codes P0305 and occasionally P0300 now with a very high idle... 1800-2200 rpms. Let off the brakes and truck would get to 35-40mph and 4th gear on its own, and maintain speed! When slowing (on the brakes) every downshift was met with acceleration! Drove like this for a month thinking it needed to recalibrate to recent work.
To no avail, returned to mechanic he said 'ECM is commanding idle at 1800 - take it to the dealer'. Dealer did a reset/relearn but was not able to identify specific cause. But no more high idle!
However the rough idle from before is back... intermittent P0305/P0300. And THEN on a cooler morning this weekend a repeat of December. Truck barely turned over.. nearly stalled ... codes now are: P0171, P0174, P0300, P0305. Running Lean both banks and misfires...
I'm thinking time for vacuum leak test, check/replace driver side valve cover/gasket, maybe intake manifold gasket, MAF sensor, Fuel injector regulator, 02 sensors... is there an order I should be checking.
Am I missing something obvious? What say you ??
Since my mechanic through up his hands I'll take it to another shop or the GMC dealer.
Can you run a misfire graph or see misfires on cylinder 5? How about a compression test?
What are your Long Term Fuel Trims once warmed up on both banks?
What work if any was done in the months leading up to these codes being set? What brand of parts were used?
steiny93
Your getting lean and random misfire codes.
Start with the basics
- what does live data show?
- what is the fuel pressure at the rail?
- test for an intake leak (spray some starting fluid or brake clean around the top of the engine, but away from the air cleaner, and see if it rev's up)
I'm thinking either fuel pressure or intake leak (it'll be something affecting all the cyclinders)
05YukonXL
05YukonXL
South Carolina
If it's a Flex Fuel engine and you're not running E85, check the alcohol content of the fuel with a scanner. Reset if necessary.
Is Flex Fuel. Previously (last dealer visit) when the idle was commanding at 1800 rpms the ECM was reading 77% Ethanol in the fuel .. fuel in the tank was shown to only be 3% ethanol via testing fuel sample, dealer reset/relearn on that.
Not Flex Fuel. Previously (last dealer visit) when the idle was commanding at 1800 rpms the ECM was reading 77% Ethanol in the fuel .. fuel in the tank was shown to only be 3% ethanol via testing fuel sample, dealer reset/relearn on that.
Yes it is if it's a 2014. The LMG and LC9 are Flex Fuel engines. Supposed to have a yellow gas cap.
05YukonXL
05YukonXL
South Carolina
Couple notes and responses:
No major work prior 18 months other what is mentioned. The vehicle had new radiator and AC condenser installed 18 months ago and it sat for a few months waiting for said parts.
P0305 does not show up under PENDING while other three codes ARE PENDING.
FRP(psi) ratings at cold, idle, revving, warm between 43.4 idle and 57.9 revving
MAP(psi) 5.5 idle, 3.8 revving, later 4.6 revving and 5.5 idle
Baro(psi) consistent at 14.9 ( 14' above sea level, 1/2 mile from intercoastal) which is what the airport is currently reporting - so that is accurate.
ALCH_PCT(%) consistent at 3.1 (is that ethanol reading?)
When revving (pushing accelerator) the motor stutters as it's grasping with command ... it holds RPMs okay, just to and from it hiccups.
Data: I need to do a longer idle and recapture more fuel trim data but here's what I nabbed so far from elcheap scanner. Manually recorded data from scan tool and pasted below. First column vehicle "Off". Next column readings right at cold start. Third column revved engine and took readings at 1700rpm. Fourth column readings once back to idle. Fifth column, did a second high 'Rev 2' 1600 rpm and took readings, Sixth Column let engine go back to idle for readings. Last two colums: took readings again a few minutes later at idle.
OFFCold Start IdleREV 1 HIGH IDLEBack to IDLE REV 2 HIGH IDLEBack to IDLELONG IDLEEven longer Idle
DTC_CNT
1​
1​
1​
3​
3​
3​
3​
3​
FuelSYS1CLCLOL-FAULTOL-FAULTCLCLCL
FuelSYS2CLCLOL-FAULTOL-FAULTCLCLCL
LOAD_PCT(%)
0.0​
22.0​
13.7​
14.5​
13.7​
12.5​
12.5​
12.2​
ECT(ºF)
109​
109​
122​
152​
156​
163​
163​
163​
SHRTFT1(%)
0.0​
6.3​
22.7​
0.0​
0.0​
-5.5​
7.8​
3.1​
LONGFT1(%)
25.8​
25​
29.7​
29.7​
29.7​
29.7​
29.7​
29.7​
SHRTFT2(%)
0.0​
20.3​
15.6​
0.0​
0.0​
0.0​
10.9​
11.7​
LONGFT2(%)
29.7​
29.7​
29.7​
29.7​
29.7​
29.7​
29.7​
29.7​
FRP(psi)
57.0​
43.5​
43.5​
57.9​
57.9​
57.4​
43.9​
43.1​
MAP(psi)
14.9​
5.5​
3.8​
5.7​
4.6​
5.8​
5.2​
5.4​
RPM(rpm)
0​
664​
1700​
606​
1600​
641​
608​
610​
SparkADV(º)
8.5​
11.5​
41​
19.5​
41.5​
7.5​
15.5​
14.5​
Next data digs deeper into first three columns but again, I need to capture more fuel trim data over longer (warmer engine) period.
OFFCold IdleREV HIGH IDLE
DTC_CNT
1​
1​
1​
FuelSYS1CLCL
FuelSYS2CLCL
LOAD_PCT(%)
0.0​
22.0​
13.7​
ECT(ºF)
109​
109​
122​
SHRTFT1(%)
0.0​
6.3​
22.7​
LONGFT1(%)
25.8​
25​
29.7​
SHRTFT2(%)
0.0​
20.3​
15.6​
LONGFT2(%)
29.7​
29.7​
29.7​
FRP(psi)
57.0​
43.5​
43.5​
MAP(psi)
14.9​
5.5​
3.8​
RPM(rpm)
0​
664​
1700​
VSS(mph)
0​
0​
0​
SparkADV(º)
8.5​
11.5​
41​
IAT(ºF)
86​
78​
77​
MAF(lb/s)
0​
0.01​
0.02​
TP(%)
30.6​
17.6​
23.1​
O2B1S1(V)
0.445​
0.115​
0.705​
SHRTFTB1S(%)
0.0​
27.3​
4.7​
O2B1S2(V)
0.450​
0.090​
0.710​
SHRTFTB1S2(%)N/AN/AN/A
O2B2S1(V)
0.445​
0.090​
0.750​
SHRTFTB2S1(%)
0.0​
29.7​
10.9​
O2B2S2(V)
0.445​
0.055​
0.720​
SHRTFTB2S2(%)
99.2​
99.2​
99.2​
EVAP_PC(%)
0.0​
0.0​
14.1​
FLI(%)
36.5​
36.5​
365​
WARM_UPS
2​
2​
2​
CLR_DIST(miles)
0​
0​
0​
EVAP_VP(inH20)
0.018
0.030
-0.189​
BARO(psi)
14.9​
14.9​
14.9​
CATEMP11(ºF)
32
746
951​
CATEMP21(ºF)
32
746
951​
VPWR(V)
12.202
13.3
14.617​
LOAD_ABS(%)
0.0
0.999
0.999​
TP_R(%)
16.9
3.1
3.5​
AAT(ºF)
75​
75​
75​
TP_B(%)
29.8
16.1
21.6​
AAP_D(%)
18.8​
18.8​
22.7​
AAP_E(%)
9.4​
9.4​
11​
TAC_PCT(%)
17.6
4.7
12.5​
ALCH_PCT(%)
3.1​
3.1​
3.1​
If only I knew how to interpret all this data!
05YukonXL
05YukonXL
South Carolina
I can switch the scanner to 'metric' readings on the next run... assuming that goes to grams/sec reading.
.01 lbs/sec = 4.53592 g/sec
.02 lbs/sec = 9.07185 g/sec
Those long term fuel trims are way off. Yeah, something might be up with his MAP and MAF readings, hard for me to tell, don't know enough.
So what causes high trims? Too little fuel. What causes that? Bad or Lazy O2 sensors or the wrong ones, bad MAF sensor, intake gasket leaks (usually the other way around, too lean) but stranger things have happened.
So, how old are your oxygen sensors? If they have been changed, when and what brand was used? Any other sensors changed? Did you try tightening the 10 intake bolts?
05YukonXL
05YukonXL
South Carolina
Thanks for the feedback. Interesting ... Got this truck second hand and to my knowledge no oxygen sensors have been changed during my ownership. Indeed the 174 and 171 codes are LEAN both banks. I have not tried tightening bolts ... but I can. (Only sensor I can think of that was changed was ABS speed sensor to help clean up some ABS/Stabilitrac dash warnings.)
The consensus is to change the O2 sensors at 100K miles. Now if you do, use only GM OE:
Both numbers are on the same box. Sometimes one number is advertised at a lower cost than the other across the internet.
05YukonXL
05YukonXL
South Carolina
Today's update:
1) Temps back up in the high 70's and the rough idle is much 'less rough'.
2) Looked at the four O2 sensors (didn't remove). The two UPSTREAM sensors have, at some point, been replaced and certainly look less weathered than the two downstream sensors that appear not to have been replaced, or at least not in a much longer time. Since both DOWNSTREAM looked weathered (maybe originals) I ordered a full set GM replacements ... Ironically, the GM BOX had DENSO branded sensors inside.
3) When I went to replace the sensors this evening I found the driver side DOWNSTREAM sensor was seized in place (you know the easiest one to access) - while the other three were easy to loosen. Will try again in the morning when I can move truck into better spot to get under it.
petethepug
Michael
SoCal
Clean and/or consider replacing the MAF due to age and milage.
Just like the other recommended advice, use OEM GM only that has the security hologram on the box. Change your battery cables because they rot from the inside out. They starve the 5V can bus of voltage and cause gremlin codes to chase.
I suspected the rough idle in our past 08 YXL Denali was injectors @ 140k mi. I sold it for our 09 Escalade ESV with the same rough idle. Replaced with OEM injectors and o2 sensors and it’s smooth as butter at 170k miles.
I shopped all the sales and got the OEM GM parts on the cheap.
05YukonXL
05YukonXL
South Carolina
Well then.. new O2s in, a few other tests and and a steady decline rather than improvements in the idle. Handed it over to my new mechanic. Compression on Cylinder 5 @40% lower than 3 and 7 at idle, better readings at high RPMS. Things pointing to bad lifter. More info in a couple days.
HeavyHoe03
