Rear driver's side window won't roll down?
ypsetihw
Lakewood, CO
when you sit quietly in the car and use the switch on the driver's door, you can hear a clicking inside the rear driver's side door, which sounds like a switch is activating, meaning it obviously has power.
I think the motor is beat. I figured I could test by popping off the door panel and sticking my multimeter in there. How do I go about getting the rear passenger door panel off?
ypsetihw
ypsetihw
Lakewood, CO
bump for help please . . . think its the motor? is there a relay I should be looking for?
retro77
I have the same problem, only its the rear passenger side. Get some flat head screw drivers and slowly pop off the panel a little at a time. for mine the plug for the motor was just loose. I need to do it again, only this time, use some hot melt glue and put a glue line to hold the two parts together.
ypsetihw
ypsetihw
Lakewood, CO
or you could solder it in there . . . I'll check and see if the connection is bad or what. I found a new motor on ebay shipped for like $40 if necessary
KMV77
Drexel Hill, PA
Just a heads up...Some of those ebay motors are *****. My neighbor bought one for his dodge caravan and I installed it. It was definitely slower than the other factory ones. It was a cheapie from ebay around $50 bucks.
Kevin
Brace
