Hard time getting Emissions monitors to set? Here's what I found.
repairman54
NW NJ
Could not get monitors to test and go green on my '11 5.3 to pass NJ inspection. No P codes or any codes for that matter. No amount of drive cycles would work. My PC based scan tool, Autoenginuity, has 2 MAP sensor tests in it. Found one test would fail erratically. I hate throwing the parts dart but that was the problem. A quick test for that issue is the real time MPG on the dash should go to 99 mpg when coasting downhill from say 55 mph. Mine would only go to maybe 70 mpg or less without touching the gas pedal and bounce up / down. New sensor and back to reading it's normal 99 mpg when coasting. Bonus was highway mileage going from 16-17 mpg back to it's normal 19 mpg with a Range AFM disabler keeping it in V8 mode. Hope this helps someone.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Thanks for the info. You still have to remove the range device and drive some cycles to pass emissions correct? I go through this crap every year over here in SE PA. There has been some in depth discussions on this subject on this forum. Specifically in this thread. Curious of your thoughts.
repairman54
repairman54
NW NJ
I pulled the Range out to make sure monitors reset. I have not verified it but I think some of the monitors need to run in the V4 mode of constant cruise to run the EVAP test.
Jumpshot12
