2022 Tahoe - Dash source list no longer includes CarPlay?
tahoe81
Since the day I got my Tahoe and connected it to CarPlay, it's shown up in the source list in the dash. I typically change the source, e.g., Sirius, CarPlay, FM, etc. using the button on the steering wheel and every source is in the list except CarPlay all of a sudden:
It's not like it's the end of the world, but CarPlay has been in this list since I bought the vehicle so it's driving me nuts that it's now missing. Did an update on the phone (I did recently update to iOS 16, but I didn't pay close enough attention if this happened with that update.
I've removed my phone from the Tahoe and re-connected it numerous times and the issue remains. Anyone else seeing this or can confirm it's happening on iOS 16 but not previous versions?
T
tahoe81
Still having this issue. Anyone care to test it out on your 2022? I've forgot the phone and disconnected CarPlay numerous times, checked software updates on the Tahoe, and clicked through menus trying to find anything but no luck.
WalleyeMikeIII
Sunny and Snowy Minnesota
Are you sure this isn't how it is suppsoed to work...logic:
Source is already on Car Play, so it is not available to select.
Try selecting FM or something and see if Car Play becomes available and FM disappears...
Ie, you can't select the current source.
Jellyfrosh
Sometimes mine does this but if I select bluetooth it comes back and just goes to the Apple Carplay screen.
T
tahoe81
No go for me. Selecting bluetooth just tells me there's bluetooth devices connected
T
tahoe81
Yep. From day one, CarPlay was an option in the dash source list. Only thing I can figure is the new iOS update changed something. Me updating my phone seems to coincide with the dash source list change but I can't be sure.
Cliff-Yukon
On your iPhone go to settings and make sure you have car play turned on your phone. If off maybe the car knows it’s not an option???
T
tahoe81
Sorry for the tardy reply.
My dash list has:
AM
FM
Sirius XM
Apple Car Play
iHeartRadio
Pandora
GoogleNews
USB
Assume the iHeart to GoogleNews require the appropriate Apps Installed
Ok so you’re still shows CarPlay. Can you tell me what version of iOS you’re on as well as version of software the infotainment system is on?
CarPlay is enabled. In the video I posted you can see I’m currently using CarPlay
StephenPT
St. Helens, OR
I’m on 16.1.2 and here’s what I see…
T
tahoe81
There goes my theory of it being related to my version of iOS. This is so weird. Maybe I can do a reset on the infotainment/dash system or something
WalleyeMikeIII
iOS16.1
Will get you
Yes, that may be a good place to start. I think there is a reset buried in there somewhere.
T
tahoe81
So I finally bit the bullet and reset everything that could be reset on the infotainment system. It fixed the issue with CarPlay not showing up in the source list. Unfortunately I have to set everything back up again but at least the issue is fixed.
moto
