A wavy of Vibrations as i drive at 50mph
jaysindix
I have a 2016 Chevy Tahoe, PPV. I am at about 199400 miles.
I've had the Transmission rebuild recently, and Engine rebuild at 140k
While I drive my Tahoe (everyday), more recently my Tahoe will have a very hard vibration. It's up front and it's only when I'm not accelerating and I'm in the Lower RMPs.
When I press thebgas and climb in speed the vibration goes away. When I coast back to a even speed. The vibration returns. And it comes in waves.
I have a video of the vibration, I don't know if it clear. I'll try to share it.
. This is the video
GMT800 2005 Tahoe Z71
Navy Supporting Member
I thought I heard a dull "thunk" noise at the 62 mph and then you acceled and I did not hear again till you maintained speed at around 70-71 mph. If that is it, that is gonna be a PITA to locate. First, you need to look for anything out of place under the hood and under the rig. It is faint enough that and since it happens while maintaining speed, I would look at wheel well covers and check any center caps and inspect ant steering and suspension components. This problem is likely gonna be something that will be a surprise to everyone or something so simple you slap the palm on the forehead.
J
jaysindix
The vibration is a whole vehicle vibration that comes from the forward center of the vehicle, maybe Transmission, maybe axel under the engine. And it's in Waves.
J
jaysindix
I would go back to transmission rebuilder let them drive could be torque converter problem.
I have the unique feeling that they will never see the provision under their warranty, but once the warranty is up, they will rebuild it again for 3k
Ok, hard to tell in the video but while in the seat, you know what you are feeling and hearing. Good call, take to the transmission builder and have them roadtest and hope that it does it for them. Best if you can drive and take one of them with you since you likely can duplicate easily.
J
jaysindix
That's a Solid Plan.
BeenChevy
Minnesota
Figure I'd chime in as I dealt with this and resolved it on mine. At first I thought the globs of grease on the rims that sometimes fall off the joints up front - nope, then thought maybe the tires - nope, u-joints - nope, then maybe the torque converter or transmission - nope... then before a big trip hauling the 32' travel trailer 7 deep I decided to hose clamp open the exhaust flapper valve. Problem solved.
Have you found a solution for yours?
Rhoward
. This is the video
Hi,
I have a 2016 Chevy Tahoe LTZ also. Pretty much doing the same thing as you described that yours was doing. When driving accelerating between 50 to 70 mph I can feel a vibration come and go. After about about maybe 5 or 10mins it will stop. Did you ever resolve this issue?
BeenChevy
Minnesota
Not easy chasing the intermittent issue. Can you check any of the boxes in the above comments? Check away bar bushings and links, ball joints, tie rods, tire wear/balance/psi, exhaust valve, trans fluid/torque converter, U-joints, etc to narrow
CrashTestDummy
Pearland, Texas
Have you installed a cold air intake? Those remove the Helmholtz chamber making pulses back down the intake tract more-pronounced when the truck is in 4-cyl. mode. It's more-evident at slower speeds when wind and tire noise are low. It immediately goes away when you move the throttle and the engine goes onto 8-cyl mode. You can almost feel it on our '12 Caprice 9C1 when it's in 4-cyl mode around 30-35.
j_jerry79
