TorqueInd
- Joined
- Jul 17, 2022
- Posts
- 16
- Reaction score
- 13
New to this forum, not to forums...
Quick and dirty... L86 Yukon... #4 bent pushrod #7 dead intake lifter... simultaniously it would seem....
On order is TSP SV cam (223/227, .635/.635., 116 LSA) factory fuel lobe. I'd like to retain VVT if possible and if worthwhile... I'm a Cummins guy boys... sorry... but i know a bit about VTEC so it seems silly to loose VVT...
AFM/DOD delete with plugs, trunion upgrade, LT4 head gaskets, Found some ARP bolts luckily, VLOM gasket, cam/crank bolts, Delphi LS7 lifters. Hope I made the right selections here... worried I dicked'er with the stock fuel lobe... but hopefully there is redemption down the road...
Basically ordered their recommendation but they send a cam lockout due to valve spring change out... springs are: 199-ISSLT1660SpringKit. Titanium retainer. 1.9000" Installed Height, .710 Max Lift, 160lbs @ 1.900", 430lbs @ 1.240". 7.850 Manton Pushrods.
DO I NEED TO LOCKOUT VVT?????
Thank you for your time fam. I appreciate all experience an expertise!!!
Cheers
Cheers
