Hey Folks
TorqueInd
New to this forum, not to forums...
Quick and dirty... L86 Yukon... #4 bent pushrod #7 dead intake lifter... simultaniously it would seem....
On order is TSP SV cam (223/227, .635/.635., 116 LSA) factory fuel lobe. I'd like to retain VVT if possible and if worthwhile... I'm a Cummins guy boys... sorry... but i know a bit about VTEC so it seems silly to loose VVT...
AFM/DOD delete with plugs, trunion upgrade, LT4 head gaskets, Found some ARP bolts luckily, VLOM gasket, cam/crank bolts, Delphi LS7 lifters. Hope I made the right selections here... worried I dicked'er with the stock fuel lobe... but hopefully there is redemption down the road...
Basically ordered their recommendation but they send a cam lockout due to valve spring change out... springs are: 199-ISSLT1660SpringKit. Titanium retainer. 1.9000" Installed Height, .710 Max Lift, 160lbs @ 1.900", 430lbs @ 1.240". 7.850 Manton Pushrods.
DO I NEED TO LOCKOUT VVT?????
Thank you for your time fam. I appreciate all experience an expertise!!!
Cheers
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon. Better minds than mine will answer your ?'s about your rig. Please post the year of the rig. You can set up your signature with all rig info for future posts.
Miami-Dade
Moderator Supporting Member
Welcome from Miami Beach!
Out of curiosity how many miles on your unit?
TorqueInd
TorqueInd
Thank you!
It’s got approx 90,000 miles.
Up here in the frozen north we idle a lot throughout the winter too. I think it’s got 4500hrs total on it, and 1500 of that is idle from what I can remember. Oil changes are done at 6000mi or 3 months.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
TorqueInd
TorqueInd
Thanks for the warm welcome.
I don’t have much for pics of this whip… it carts the wife and kids around and I usually end up with a speeding ticket on road trips lol
Here’s a pic of the carnage I’m into now!
TorqueInd
TorqueInd
Geotrash
Dave
Richmond, VA
Cheers
Is it a complete VVT lockout or just a limiter? According to the TSP site, that's the valve spring set they recommend for that cam, so that's curious to me. Locking out the VVT would be necessary if the valve spring pressure is too great for the cam phaser to overcome the resistance while the engine is running, but that doesn't seem to be the case. Might be worth a call to them to verify.
Factory fuel lobe should be fine unless you're planning to add a supercharger.
TorqueInd
TorqueInd
TSP did tell me the reason for 0 degree lockout is due to the heavy springs, and not being able to control the timing properly like you said. Seems strange to me, as RB26 engines utilize VVT, as do a lot of high performance engines. Anyway, it’s got the lock in now and is back together.
It’s running, not tuned yet, but running. Should have a tube in a day or so.
But wow the electrical gremlins now…
No power steering.
Infotainment screen won’t shut off and is black but backlit, and killed the battery overnight.
Christmas tree of warnings…
Double and triple checked all the grounds… pulled the infotainment fuse tonight to let it charge… fried my multimeter checking for dc amp draw… headaches… just when I thought I seen the light lol
Any ideas what is causing the electrical problems? Battery was undone for about a month now… about all I can figure is take it to a shop and have it cleared with the snap on scanner and update the infotainment… hope for the best
Geotrash
Dave
Richmond, VA
No power steering.
My guess is that battery has an internal fault or low voltage. These trucks get all wonky if the battery isn't perfect. Once you get it charged, unhook it for a minute, hook it back up and try again. If that doesn't do it, then I'd try a new battery.
TorqueInd
TorqueInd
Borrowed a snap on scanner from a shop owner, had 40+ body module codes. Did you guys know these things have 25 modules!? That’s 25 computers running these beasts… wow
Hate to admit it, but I missed a ground putting the car back together… right point blank in my face, right on the alternator bracket… was getting rushy close to the end I guess. Had the wire tucked down in the crossmember to keep it out of the way.
As silly as I feel, I’m glad it was a easy fix… now just waiting for the tune so I can take it for a drive!
Geotrash
Dave
Richmond, VA
Ain’t nothing silly about it. These trucks are electrically complicated, you did major surgery, and that’s an easy ground to miss. You also had the courage to come back and share what happened. Hats off!
TorqueInd
TorqueInd
Well. Few weeks later now. Runs, drives, etc. Tuning is usable, but definitely was a struggle to get where it is now with the tuner. Also hearing crickets now for the re-tune after sending data logs. Unfortunately, I haven’t had the time to actually learn how to properly tune yet, but I have purchased a lifetime membership with HP academy, so I have the tools to learn, just not the time right now.
I did however learn there is a VVT capable cam option. Too little to late now unfortunately. Can’t recall the maker but I will find out if anyone is interested.
Overall it runs a bit lumpy. Goes pretty violently. Put a smile on the kids faces when I opened it up. Pretty impressive acceleration for a land yacht. See how it does with time but, it won’t fail from dod anymore so, that’s a win.
CKendrick
