Any of y'all need/want a Corsa cat-back for your 62.L XL or Burb?
Anyone need a Corsa kit for their XL, ESV or Burb with 6.2?
Sparksalot
Bastrop County, Texas
I thought about that. I’ll keep the old one to experiment with in case I don’t like the results with the low temp tstat.
Well GM #86774933 is NOT the replacement for a 2015, due to the quick release cooler lines. The guts however drop into the old housing.
No leaks so far and the temp is lower after a 20 minute highway drive at 85 in 100F heat.
Sparksalot
I also admired it in the driveway.
jd08
Jackson, WI
Installed escalade mirrors on our Yukon. They look great and I can't believe the huge upgrade this is for visibilty. You can see so much more. I recommand this upgrade.
Had 2 issues. First is my mirror glass shake a little while driving 55+ speeds. Looking for a fix for that. Other issue is the passenger mirror powerfold doesn't work and L+R adjustment also doesn't work. Everything else does. Seller refunded my money so I am looking for a different passenger mirror. Current set up only cost me $150.
Tonyv__
Bucks county PA
Where did you find mirrors for $150. I can’t find decent mirrors under $450 a piece. Anything less is either damaged or missing covers
jd08
Jackson, WI
This is the seller that I got the brand new takeoff mirror that worked for $150. See link below. Other one was from a ebay seller and didn't fully work and was refunded my money. Currently working with the seller below to find a passenger mirror with my features I need.
https://www.priorityautoparts2015.com/
RST Dana
OH
Either the mirror glass is not fully snapped in place, or possibly your three attachment bolts may not be tightened enough.
RST Dana
OH
Lookup the part number for an Esky then search eBay or Google for that number.
jd08
Jackson, WI
Mirror glass is fully seated. The up/down adjustment works just the side to side I hear no motor running. Also powerrfold I don't hear the motor running. My wife was running the controls when I was listening. Blind spot, signal, and puddle light work.
The three bolts are tight. I actual installed it twice. I installed it and noticed it didn't work so I reinstall the yukon mirror to make sure I didn't screw up any wiring. It was all good, so I installed the Escalade mirror again and same thing. I was refunded my money so I am not too upset. I will find a new one and swap it in.
Sparksalot
Taking advantage of the deck plate I made to install the fridge and Jackery.
Plus anchor points for cargo boxes.
Ghost10
Well since I don't drive at night oftenand I rarely use high beams because the low beam HID cateye lense does a very good job of spreading out the light with a regular bulb, I've decided to go JDM style just a tiny bit and swap out my 9005 hi beams with these:.
9005 HB3 LED RGB Fog Lights Bulb Amber Yellow White Multicolor 16 Color Changing Switch Kit Strobe Lamp Bulbs for Car Trucks Remote Control Switch Error Free Plug and Play 12V 5050SMD Replacement【1797 https://a.co/d/7KyhgyE
They'll be delivered today and will install tonight. Also pulling out brown and white and purple and white wire from under the dash and running a resistor in-between so fogs andnhighs can be on.
Ghost10
Installed one of my ham radios. I ran power straight from the battery into the cabin. The extra studs at the positive terminal were handy.
So was the floor plug under the passenger floorboard.
View attachment 376066View attachment 376067View attachment 376069View attachment 376070View attachment 376071
Nice setup I too use proclipmounts and just recently switch to rammount. I'm running a XTL5K and a Uniden HP2. What antenna setup you using ? I originally had a comet lip mount on the driver side door jam but have finally Swiss cheesed the roof with 2 NMOs. Let me tell you when you switch from a lip mount to a Nmo the RX end is stellar now !
ScottS-Michigan
