2005 Tahoe LT HVAC Mode door actuator.
TontoFAC
Florida Panhandle
I have replaced the mode door actuator and completed the initiation process, and the actuator seems to be recognized by the system. However the actuator still does not respond to inputs. I have also replaced the control module and did the initiation procedure on that. Is there another part to the HVAC that would prevent the actuator from responding to inputs? Does the 05 Tahoe HVAC require to be initiated using a scan tool?
A relearn with a Tech-2 or equivalent ought to be done after replacement of an actuator. Replacing the control module requires programming on a GMT900.
HiHoeSilver
Away!
Chicago
Do you have the digital controller? Have you tried the basic reset shown here:
One of mine wouldn't come off the floor no matter what I hit. This procedure got it working again.
TontoFAC
TontoFAC
Florida Panhandle
Thanks, I think you just saved my mental health. I have the manual system. When I looked up this procedure I forgot to write down the last step to turn ignition off for 10-30 seconds. I'll update tomorrow. Thanks again.
