4x4 Beach Driving
Chuck_Finley
Hey Guys,
I'll be visiting the Outer Banks in NC later this summer and plan to drive my 2011 Tahoe 4x4 on the beach. I have never taken it off-road anywhere but I've watched some Youtube videos on beach driving best practices and will have a tow strap, 2 compressors, shovel, jack, 2x4, and pressure gauges. I have a factory suspension, 20" wheels and newish all-season tires. I know to air down to 15 ish PSI. Do I have anything to worry about as long as I take it easy and try to avoid large ruts? I've read that it may be best to remove the lip at the bottom of the front bumper for better clearance.
Any advice or tips would be appreciated! Thank you.
Geotrash
Dave
Richmond, VA
Hey Guys,
We take our 2012 Yukon XL Denali down to the Outer Banks all the time. We have a beach pass. It does great, all you gotta do is air down to about 20 psi and you won’t have any trouble at all.
if you are driving on the nice packed down sand just above the tide line you are fine you don't need to do anything but cruise, keep an eye out if it looks too wet go around it.
keep a nice steady speed.
personally on these vehicles i see no need to air down the tires at all unless you are running mud tires or something I don't see any benefit and have never aired down on the beach, I used to live a block from the beach and lifeguards drive on it all day long in regular pickups, never seen one get stuck.
i have seen regular low to the ground sedans get stuck, like completely stuck and then continue to try dig themselves in a deeper hole.
Geotrash
Dave
Richmond, VA
OBX is different because you have to drive through 100-200 yards of deep dune sand to get to the compacted sand near the water. Coming back out you have a significant uphill to battle. We watch people get stuck there all day long. I’ve been bogged down a time or two but was able to rock myself out. Just for giggles I aired down to 20 psi last time and it was a game changer. Could stop in the deep sand and walk it right out.
One more thing for the OP, turn TC and stability control OFF by holding the button down for 10 seconds. You don’t want the TC slowing you down out there. It’s counterintuitive, but TC will get you stuck in deep sand.
robgreg75
Well if I am not afraid to take this to the beach (and I removed the AWD system) you will be just fine. Just don't go in the really soft sand. The worst stucks I have seen at the beach are when people park too close and the tide came in. One day it took 3 trucks to pull out a suv stuck after the tide came in.
EddieC
Never had any problem with either Tahoe or any Jeeps. Smoother tread tires are more suitable.
It used to be the last frontier but the last time we went, after the Park service lost a lawsuit to the Audubon Society, there were many beach closings due to bird habitat (and it changed daily) and permits were required which were only issued after taking an on site class. We'd been beach driving there for 20 years and now we needed to take a class and pay quite a bit for a week long permit. Prior to that you could just turn off the road onto an access and find a spot of solitude out there.
It's not the place that it was in the 90's. Hope you find it worth the trip.
exp500
Hope you are from frozen north rust belt, cause thats what that truck will resemble after beach trip.
grouch
Hey Guys,
Make sure you go to a car wash afterward and rinse the under carriage REALLY good. Ocean salt water is a little, not much, but a little worse than salty Michigan roads. The finer mist gets into everything. I think the fire department in Los Angeles has to replace the Jeeps they use on the beach every 3 or 4 years. The frames just fall apart.
nick0789
1) The amount of rain the OBX gets before your arrival will also heavily influence how much effort you’ll need to exert to get through the sand. I go down to Ocracoke every summer and with normal rain patterns I rarely have to go into 4WD (I have an 05 Z71 tahoe). Last summer was tougher because we had very little rain for the few weeks leading up to my trip so I had to stay in 4WD pretty much the whole time I was on the beach. If you get through the dune sand (aka the beach access roads) just fine and down to the high tide line you’ll be cruising with no real effort. I did get stuck briefly last summer after parking but that was my own fault: I park with the tailgate facing the water and I usually go into reverse and turn when I leave for the day so I’m parallel with the water to get some speed going before turning into the softer sand. This time I was in 2WD and just went for the gas and the back of the tahoe sank. A little rocking and I was good to go but still keep an eye out. These vehicles will sink pretty fast if you don’t pay attention. Instead of a 2x4 for a jack base, I’d recommend something square with a larger surface area (at least 12”x12”, but that’s just me being overly cautious) if you’re that concerned about it. I’ve seen a 2x4 get pushed into the sand with the jack.
2) If you haven’t gotten one already, the hatteras seashore permit it’s $50 for the week. It’s been $50/week for the last 7+ years but it’s worth it to get away from everyone else that uses the regular beach access points.
3) I agree that ~ 20 psi is your best bet, though I’ve had to go down to almost 15 in my old Jeep before, just to not spin too terribly as it’s got an open diff.
4) watch out for the turtle and migratory bird nesting sections. They are always roped off and if you get somewhat close to them don’t be surprised if a ranger talks to you about it.
5) Keep an eye out for larger sections of driftwood, too. They usually don’t extend much further than what you see but I’ve seen people pop a tire by driving too closely to some larger trunks.
6) you’ll be able to tell pretty easily where most of the vehicles have been able to navigate and where people may have had trouble. I tend to follow the tracks closer to the dunes that run parallel to the water unless there is no one out near the water. Then I’ll take the harder-packed sand route every time. Expect some tire squealing from the sidewalls rubbing the ridges of the tracks in the softer sections
7) hose off everything (including underneath) when you leave the beach for the last time on your trip. If you’re there for only a couple of days (less than a week) then I wouldn’t worry about spending the time to hose off after every beach session.
8) wear sunscreen.
9) have fun!
liveaboard74
You guys talking about my playground. :)
Heavy mods on that Tacoma but even thought it was one of the most tricked out trucks, I hated it. Size.
Sold that bought the Tahoe doing the very same thing to it now. Got the lift Monday, waiting on 2 inch adaptors for the rims and tires. Read most of you guys post but some of you are wrong on just go drive .
LEAK THOSE TIRES DOWN. 15 pound . Hatteras we have whats called Suger sand. I'd advise you not to go there. 12 pounds on the air adn 4x4 is a must. NOrth beach is your best bet.
IF you don't air down this time of years you will get stuck. I actually run street tires but do the 15 pounds. More contact than A/Ts and they don't dig. Start and stop slow. Honestly everyone loves to post pictures if you don't have a 4x4 don't hit OBX. You will be everyone's picture. LOL . You will make front page on our OBX beach forum. OBX towing always post their adventures. ( Hook ups) LOL
Jeeps 4x4 trucks, even hummers get stuck when they don't leak down. Town trucks around there run 20 pounds of air but they are running 285, 95s and 305s. . Leaking down increases your foot print and you roll with the bumps not push through them. Thats the secret to OBX driving.
Tahoe is about 4 weeks away from being finished. If you head to OBX give me a shout GF and I can met you. Have every other weekend off, were there at least once a month in summer more in fall. Grill out, music cold beer, fun and sun backed up to the beach. We live on the water cross the sound. Elizabeth City . Several boats one's a offshore fishing boat. Won't kidding OBX is our play ground.
SEE ya...........:)
no, lol maybe if they lived there and literally lived right beside the beach, I used to live 1/2 block from the beach nobody's cars rusted unless they parked like basically on the beach for years and years.
EddieC
Well if I am not afraid to take this to the beach (and I removed the AWD system) you will be just fine. Just don't go in the really soft sand. The worst stucks I have seen at the beach are when people park too close and the tide came in. One day it took 3 trucks to pull out a suv stuck after the tide came in. View attachment 376521
Robgreg, That's way too much population for the reasons we went to Hatteras. There were times when the next vehicle was on the horizon.
EddieC
It was just part of the experience for us. The thrill of having the beach to ourselves was worth anything.
we were there on one trip when they were moving the Hatteras light house due to erosion, and we asked the ranger on hand if the area was a good place to buy a house. His answer was "it depends on how soon you can afford to lose the money, because sooner or later you will and have to decide if it's worth it." Beach driving was a worthwhile experience but we were knowledgable enough to stay out of the water zone.
EddieC
Hey Guys,
Add a square 18"x 18" of 3/4" plywood on your list to put you jack on. That's from the state of RI beach driving requirements and the OBX sand is a piece of cake compared to RI where the sand behind the dune seems like powder. Our tires were sunk in up to the rims while traveling their sand trails and it was tense times for sure.
Charlie21ny
