Brake Upgrade. Whats best?
96ProCompTahoe
IN
Need to beef up the brakes on the Hoe. not looking to throw a ton of money into swaps but what are you all running?
I've got a used rear disc kit in the garage from Stillen. not sure if its really going to be any different that the drums (other than looking better)
big Q is the front end, is it worth the $1000 kits for bigger rotors? or better to just put on higher quality rotors and bigger calipers with the stock hardware?
Also was a topic on TF before it died. the Hydro-boost conversion worth the money?
bowtiefreak
No Quarter
Near Philly
bigger is better in brakes....if you have the money. I am running stock size cross drilled and slotted with Hawk pads and the ABS unhooked. Stops way better than stock
JennaBear
Resident Ninja
San Diego, CA
I have R1 Premium rotors and Hawks pads with stainless brake lines. Very happy with the results!
blueflamed03
Oklahoma
Max has said good stuff about Power Slots and Hawk pads. Agree, stainless brake lines help as well.
destroyer1362
A work in progress
Midlothian, TX
How does unhooking the abs help? Just curious bc brakes are on my to do list as well.
96ProCompTahoe
IN
my abs has been disfunctional since the re gear. already has stainless lines on the front, rear will go on with the disc swap.
been debating the slotted rotors and of course better pads.
anyone running rear disc? need to know if i need a proportioning valve to make them work correctly.
bowtiefreak
No Quarter
Near Philly
Stainless lines also, forgot that one...it was a must with the lift so I always forget.
Unhooking the ABS:
First, the system is not setup for a 35" tire and that leads to the following problem.
When you press the pedal hard the ABS computer senses the amount of pressure and determines that tires lockup is imminent and begins to back the pressure off the system causing really crappy stopping. Simply pulled the fuse and went out for a test drive...works like a charm now. Firmer brake pedal when stopping. ABS being unplugged simpley reverts back to standard braking
96ProCompTahoe
IN
wait wait wait. i heard you couldn't pull the fuse on it cause it'll kick in and work worse than it already does on 35's.
I'll have to try that though. those short stops are a PITA right now.
so the parts list so far:
-Power Slots front (and rear if i can figure out what those Stillen disc's are actually off of)
-Hawk Pads (front and rear)
-Put on the rear disc kit
-rear stainless line.
still need to find out on the proportioning valve and the hydro boost conversion.
bowtiefreak
No Quarter
Near Philly
pulling the big fuse under the hood. Completely disables the ABS. Trust me, it will lock them up now with no problem.
bass1775
Maryland
Brakes have always been a problem on my tahoe. I drive aggressively. Is there a big brake conversion for the 98's? Everything I've seen is for the 2k's and newer. I'm running slotted and crossed drilled rotors up front w ceramic pads and stainless lines. They stop better than stock but, could be better. I still have the drum brakes on the rear.
blueflamed03
Oklahoma
look at Baer?
bowtiefreak
No Quarter
Near Philly
keep in mind that a big brake conversion may also require a bigger wheel to clear everything. Another option is drive slower?
96ProCompTahoe
IN
most of the big brake kits i've seen require 18's to clear the new rotors.
---------- Post added at 08:03 PM ---------- Previous post was at 07:47 PM ----------
hey does the ABS light stay on when you pull the underhood fuse? i'm sick of seeing that damn thing.
96ProCompTahoe
IN
dang, was hoping it would get rid of the light.
when i finally have time and money to buy/work on the hoe i'll get it tuned and it'll fix the ABS as well. no more light
that or tear it all out and go to the hydroboost conversion. haha
jmildoc
Indianapolis,Area
just go to Orielly and they will have anything that you need.... I know the manager at the one in Martinsville and can get you a discount if you want to come up this way.....
Buford bubba
