Hummer H3 5.3 engine mount - online vendor?
Charlie207
LFOD, New Hampshire
I see that the price for the H3 engine mounts shot up, right as I go to order. It's at $235 currently.
The cheapest AC Delco mount I see is at AutoZone for $148.99, but I'm hoping that someone else might have a better lead.
IIRC, the when they were on Rock Auto I think they were only like $90.
Charlie207
Charlie207
LFOD, New Hampshire
I just bought the AC Delco H3 mount from AutoZone for $133 (found a $15 discount code), and if I find a better deal, I'll return the AutoZone item.
Just08yukxl
Do these only work for the 5.3? I've got an 08 with the 6.2 and my drivers side mm is broken again and it's less than a year old.
robgreg75
I replaced my drivers side mount yesterday.... pain in the ass would be much easier on a 2wd.
Anyway I got a engine mount from Summit for $31 you just have to reuse the engine plate and the heat shield. Part number ANI-3211.
Charlie207
Charlie207
LFOD, New Hampshire
Is this the equivalent to the Hummer mount?
I already replaced my driver's side, and with the 4wd, it was a bit more of a PITA. I removed the steering shaft, manifold heat shield, and jacked up the engine until I could origami it out of the bay.
robgreg75
It is a standard solid rubber mount. I didn't remove the steering shaft, I unbolted the heatshield and plate then was able to get it out through the fender well.
CrackerJack135
