Crossmember Removal to Track Noise
Blk00ss
We have a 2005 Tahoe 2wd. Does anyone know if I can remove the crossmemeber (below oil pan) and simply back out of my driveway just to try and diagnose a noise? Will there be any ill effects of me removing it and putting tires on the ground and simply backing up slowly? I know its probably a stupid question, and I don't believe it will hurt anything just backing up a few feet, but thought I should ask just to make sure
mattbta
Frisco, TX
I doubt it would hurt anything, but don't take my word.
That said, I have observed mysterious noises when the bolts for that crossmember weren't torqued properly (too loose).
B
Blk00ss
So my son has taken this vehicle over. Its in great shape, but we have this loud creaking noise (metal to metal) but almost like an old barn door type noise. I've been all through the front end, We've replaced lots of parts (not because of this noise), I've got new wheel bearings, greased everything etc and it still makes the noise. And I found a post of someone on the Escalade forums talking about an identical issue that actually had a TSB (don't recall the number) at one time. But I did have that crossmemeber down back in January when I did the oil pan gasket and pickup tube O ring. So my thining was remove it, back up a few feet, and we'll know whether or not its that.
It attaches to the frame, so I *think* it would be fine. but would love someone to confirm if possible.
mattbta
Frisco, TX
Maybe first, make sure the bolts are fully torqued ( :laughing1:). However, Service Information has conflicting values -- in the oil pan install section, they state 74 lb ft, but in a TSB for noises, it is listed at 89 lb ft. In the TSB, it's also stated that 2005 already has crossmember holes enlarged.
  • OIL_PAN.pdf
  • 1548730.pdf
B
Blk00ss
Thanks. I saw the 89ft lbs as well. I realize the holes are suposedly enlarged for 2005, but I was wondering if it had something to do with the rubberized coating that seemed to be on the hardware and memeber itself when I removed the crossmember. Naturally, much of it came off when removing the nuts and bolts.
without risking the possibility of the engine expanding the frame there, you could just loosen the bolts up a lot and try it that way, just pure speculation.
I had a similar problem once, unexplained noise and after multiple, multiple, multiple times of trying to find it one time while it was up on a lift I noticed the left lower control arm bolt hole had a shiny part above it (like it had been moving up/down and made bare metal appear) so we pulled the nut off and the lower control arm bolt hole on the frame had become elongated (egg shape), so we found a really big thick washer and welded it on the frame because there was no other fix and the bolt still had enough room for the nut, worked out great and it was never a problem again even at 324k when I sold it.
my point is to check everything in the area, it could be more than just the cross member, which I had that checked on mine as well the typical fix for that is to remove the bolts and lottery them back on there randomly and re-torque.
another thing that will make noises is the sway bar bushings, take off the D bushings grease well inside and put them back on.
B
Blk00ss
Yeah, we're definitely considering everything. I've replaced tie rod ends (which helped a ton with tightening up the steering), replaced shocks with Bilstein shocks, replaced sway bar end links and bushings, haven't done sway bar bushings yet, but that is next even though they actually look really good and still have their shape. They've also been lubricated. Everything that has a grease zerk has been greased, everything that doesn't has been greased manually. I've checked everything, multiple times, I have sprayed everything mutliple times with silicone spray just to see if the sound would get quieter or go away temporarily. It doesn't. I've also wondered if maybe its the body mounts because the sound does seem to fade when we've had rain and the undercarriage has gotten wet. Of course, that may also point towards the cross member issue as well.
ya that's pretty typical when it would rain then mine would start making noise again and most of the time it was the sway bar bushings
B
Blk00ss
Was your sway bar bushing noise at low speed? Ours is literally if you back out and or pull forward in our driveway. Very very low speed
yep as soon as a wheel went down turning out of the driveway, but it could be other things as well, it can be really annoying
TollKeeper
Brighton, CO
I have seen dry ball joints, tie rods. and mis-aligned or worn out pitman arms and idler arms, cause the noise you mention.
I have also seen blown control arm bushings do it (front and rear)
B
Blk00ss
I am happy to report that it was in fact the crossmember. When my son got home I pulled the truck in the garage, confirmed the noise was most certainly still there (it was really loud today), loosened the nuts from the bolts and backed out of the driveway...Completely silent. Pulled back in, torqued everything down, backed out of driveway again turning the wheel both left and right and still completely silent. Really glad I'm not chasing this one anymore!
mattbta
Frisco, TX
Great news.
BTW - I was the original owner of a '99 30th Anniversary Trans Am. Assuming you have/had a black 2000 SS Camaro based on your handle?
B
Blk00ss
Great news.
Nice!
I'm a bit of an American Muscle car guy. I've owned '71 Olds Cutlass "S", '94 Z28 M6, '00 Camaro SS M6 (with all the SLP options) which I drag raced as well as autocrossed, and last May I sold my '05 Pontiac GTO LS2 M6 with 45K. All my cars were very very nice and well taken care of (I'm somewhat OCD with vehicles). I currently have nothing other than my dirt bikes, but I think a C6 Z06 is in my future. They're just awesome cars and plenty of bang for thr buck.
robhotdog
Miles? Not much Info on how and when. What first came to mind was U joints! I've seen first indication is Squeek In reverse. Easy ck
varminpoolteam
