Extended Wheel Studs
emilime75
Wondering if anyone knows of a longer than stock wheel stud. Need them to be at least 1/2" longer, or more, I can always cut them down if they're too long.
Thanks
Yukon John
SE florida
Check with NAPA...my friend needed stand off spacers when he put 14" Willwood Rotors on his '14 Escalade and I believe he got the wheel studs he needed at a NAPA store.
E
emilime75
Never mind, found some at Autozone. In case anyone else is needing some, Dorman 530-610 is the right diameter, thread pitch and knurl. They're roughly 1/2" longer than stock and the threaded portion goes out further, about 1/4", effectively making them about 3/4" longer. Worked out perfect for a 1/2" spacer.
JAEe
Good morning I just came across this thread. I looked for that dorman part number and it doesn’t exsist. I even searched 610-350 and those studs are for Fords. Either way are you still running these studs
Tmmm
Need help with 1/2 longer wheel studs for 07 tahoe
S33k3r
Dallas, Texas
I'd suggest starting a new thread. If I knew I'd tell you, and often I'd share some forum search results, but I'm traveling today, sorry. In case it helps, should be the same for the same year 1/2 ton Sierra and Silverado.
Do you need to get studs to run spacers?
87carl
It is actually "Dorman 610-530" lug studs for rear of a mid 2000s f350 dually. Amazon has them in packs of ten or go to rock auto or any parts store and look up lug studs for rear of a f350 dually and you will find them.
kootamcgrabbin24
