03' Yukon Body Drop
89 chevy
Well today I finally body dropped my Yukon. It was definatly a fun time doing it! I took some pics, but there in my Yukon and its still at my shop. It took us about 2hrs because we took our time. Just the body drop lowered it 1.25" at the very least. We made little rubber inserts to go inbetween the body and the frame, but they were only like 1/16 thick. Like Clean95 said, the only hard part was the front, and it wasn't even that hard, it was just a pain in the ass. Here is 2 pics from my cell phone, and there not the best. If you guys have any questions just ask! Thanks to Clean95 for the help when I called him today!
The first pic is just the body dropped down. No bolts or tightened, and the spring Isolaters still in.
Will get more pics tomorrow!
89 chevy
No we had to do some cutting, and grinding on the factory mounts.
---------- Post added at 09:32 PM ---------- Previous post was at 09:15 PM ----------
I will get more pics up tomorrow, but I don't think u can body drop your 08'!
89 chevy
Like I told Clean95 lastnight I found out a way to lower the body about a half an inch, but you will have to drop the front and rear bumper down. Right now, I cannot stick a pencil between the bumper and the hatch. I can't even fit a cutoff wheel inbetween there either so the bumper will have to be moved. Im going to trim a shock bolt now thats almost rubbing on the tire, so I will have pics up in a hour or so.
Max
Mile High
Denver
You should be able to flip the rear upper shock bolt around so they don't rub. I'm interested to see how this pans out once you correct the bumper height, that shit is all over the grill right now.
89 chevy
Thats what I did max. The rear hatch is so close to touching the bumper, its crazy. The more I measure today, it lowered it right at a 1.5" in the rear, and 1.25" in the front. I am very happy I did it, but it is a little louder in the cab going over bumps, but It's not even that bad to worry about it!
Here are some pics!
Just got it on the lift
The piece you cut. You cut the circle part that is stucking up flush with the cup.
This is how you can make it lower, we cut this one just for an example to show you guys then welded it back together!
The little rubber piece that we put in place of the big bushing. This is just so the frame doesen't squeak against the body.
This is how far we lifted the body from the frame.
Cutting and Grinding
First time off the lift!
Pics that I took today!
The gap between the grille and the Bumper.
The gap between the rear hatch, and the bumper! Can't even it a paint stick between it! haha
---------- Post added at 06:09 PM ---------- Previous post was at 06:05 PM ----------
The reason it lowered it more in the back than it did the front was because the front 2 bushing were a little thinner than the back ones. Why I don't know, but mine were!
BOSS
The People's A D M I N
Dallas
Great job, looks good as hell....can't wait to do it myself :waytogo:
Any reason why you didn't go with S10 bodymounts instead of eliminating your OEM? Seems you would get the 1inch drop and still retain the shock absorption from the shorter rubber bushings.
I asked clean also, I've got a complete S10 set sitting around waiting to install....
B
BOSS
Dallas
Also just curious how you guys went about lifting the body up with it on the lift so high in the air....floor support jacks??
B
89 chevy
We used a tranny jack, with a piece of square tubing and thats how we lifted it up.
chistoso
Arizona
That looks really good.. I wanted to do this to the Tahoe when I had it because I had about one inch of gap between the front bumper and the body I wanted to close up and the same out rear. The front gap looks perfect, if you can figure out a way to get the rear bumper to clear 1/4 inch of the hatch it'l be nice..
89 chevy
Thanks everyone. Im getting a bigger sub box, and were gonna take the Isolators out. Im gonna get the rear to tuck without 500lbs in the back, and doing it the right way.........haha
---------- Post added at 07:37 PM ---------- Previous post was at 07:36 PM ----------
B
I wanted to get it dropped right away thats why we didn't wait.
BOSS
Dallas
Hell ya, agree 100%...I think a rollpan would be perfect for that.
B
89 chevy
I always thought of a rollpan, but i don't know if I want to have to buy a hideaway hitch, just in case I need to use it. Who makes good roll pans and hideaway hitches? Do you have to remove the rear tire for a hideaway hitch?
BOSS
Dallas
Yup no tire....Sir Michaels makes a good hidden hitch. Mine is still in the garage... :(
B
89 chevy
Well, I won't be using a hitch then! Who makes the best roll pan in your opinion?
pats hoe
absecon,new jersey
Ill be doing a roll pan anyway so that will take care of that.For the front ill just modify the brackets.Looks great sitting outside.
Brace
