Side mirror trailer cameras?
ItIsWhatItIs
Does anyone know if the Yukon has the same side mirror cameras as the Sierra that allow you to look down the side of the trailer while driving? I was under the impression this is part of the max trailering package with the Yukon, but after looking at all of the trailering info out looks as though the 15 camera view is only available on Sierras:
NYisles1
In my '22 At4 it does. When a trailer is connected it automatically displays the view down the side of the trailer when you put the turn signal on for the direction you're turning. You can also manually find that display using the 360button. We took a 600mi round trip over the holidays with a utility trailer and i really came to like that feature.
ItIsWhatItIs
ItIsWhatItIs
I’m assuming you have the Max Trailering Package?
NYisles1
Been trying to figure out which package that is part of. Im not sure its Max Trailering- it may be the Prograde Trailering system? My At4 came with all of them (I bought one someone else had ordered and then backed out of - they had set it up with every option). These are all the options on the '22s:
ItIsWhatItIs
ItIsWhatItIs
ProGrade is included with Max Trailering as far as I know so I’m guessing I’ll be good. We just resubmitted our order last night with all of the same trailering options you have so as long as it gets built that way we’ll be good. Thank you for confirming, really appreciate it!!!
NYisles1
Good luck with your order! We towed a camper and utility trailer for years with trucks without all this tech but I have to say it is nice to have. On our trip over the holidays I just had a utility trailer with snowmobiles but being able to monitor the trailer tire pressure and look around the trailer is a very nice feature. What are you towing ?
ItIsWhatItIs
ItIsWhatItIs
I agree. For my first 6 years in construction I towed a 10,000 pound trailer pretty regularly. It worked but man was it stressful at times driving hundreds of miles in rush hour Phoenix traffic.
We currently have a 26’ travel trailer. My main concern for the mirrors is our current 2020 Ram Ecodiesel, which didn’t have a tow mirror option when we bought it, is terrible to see around when making lane changes. It does have the lane changing sensors that get extended 30’ from the back of the truck when you plug in a trailer, but I don’t trust that technology like I would a camera.
kllerzomb
I've been looking around, what does the auxiliary trailer camera connector look like? Even if the transparent trailer view isn't an option for a Yukon/Tahoe/Suburban, can you get that rear of the trailer view if you wire a camera? I've seen the "Park Assist Camera - GM (85004154)" which shows Tahoe/Yukon/Yukon XL/Suburban vehicle fitment, but doesn't clearly show which other packages are required.
  • Other Names:Trailer Auxiliary Camera (Models W/Trailer
  • Description:
    Expand your field of vision with this Trailer Camera Package. It provides additional driver-activated views projected on your vehicle’s infotainment radio screen. It features a manual touch-screen menu, offering multiple vantage points around the vehicle.
2022ChevroletSuburbanHigh Country, LS, LT, Premier, RST, Z713.0L L6 - Diesel, 5.3L V8 - Gas, 6.2L V8 - Gas
The image doesn't help much.
NYisles1
If you get the aux trailer camera option then the 4 pin plug gets replaced with inputs for the camera. You still have the 7 pin trailer plug right below it.
NYisles1
These cameras and the towing tech are probably a big plus for towing a TT. Will be interesting to see what you think about the overall platform vs the Ram. Which engine did you order?
kllerzomb
Thanks, that is very useful. I just have the 4 pin plug. Might take a look at some of the magnetic mount battery powered WiFi cameras.
ItIsWhatItIs
ItIsWhatItIs
3.0 Duramax. This is our second EcoDiesel, first one was part of all those recalls for the EGR leaking into the intake manifold. Ours almost caught on fire so that was fun. We had just bought it used so I took it to the nearest Ram dealer and they made it right but we had to get a 2020 to make it all work. At first we were reluctant, but when I looked at all the work that had gotten them to iteration 3 of that engine so quickly I was hopeful that they had finally worked most of the kinks. Knock on wood 36,000 trouble free miles so far. So hopefully the fact the Dmax has been in the Silverado for a few years now and we haven’t seen any major changes means Duramax already had a thorough understanding of the American style emissions systems and had a leg up from the start.
NYisles1
Good choice - especially with a TT I think that’s a home run. Hard to believe the Dmax is in its fourth year already. Doesn’t seem like there have been any major issues. Wish it had been available in the At4. The 6.2/10spd is great but I averaged 11.8mpg over about 600 mostly highway miles with a 14’ open utility with 2 snowmobiles - I bet the diesel could almost double that.
Yesssir29
Did you have this added or was it factory built with this?
NYisles1
Came that way from the factory. I'm not sure if it can be installed by dealer - hardware should be easy enough but updating the software might not be.
BadDaddy2003
