ABS Light With No Codes
MassHoe04
Western MA
Just got a a 2004 Tahoe Z71. Approx. 194k miles. Needs rocker panel replacements (planned for tax refund next spring).
Runs smooth as butter and LOVE it!
I have a single CEL/code for B2S2 Oxygen Sensor, but no other codes and runs fine otherwise.
Every time I get up to 55+ MPH on the highway, the ABS flashes/chimes and stays on for a bit, then keeps repeating the annoying cycle until I get below 55 MPH again.
As soon as I get below 55, the light goes off and stays off. There are no codes related to ABS on the scanner. Driving around town, no ABS light or chime at all driving less than 55 MPH.
Does this sound like the old corrosion under the ABS sensor issue? Given what I have described, what are the odds of any sensor actually being bad?
I will try cleaning the hub under the sensors and see if that clears the issue on the highway, but wanted to see what you all thought.
Cheers!
afpj
Stupid question, but you sure your scanner can read abs codes? If you can see live data, track the sensor speeds at each wheel as you go above 55 see if one or more read incorrectly. Cleaning under the sensors is a cheap start otherwise. Smarter people should chime in.
MassHoe04
MassHoe04
Western MA
I think the flashing light is related to the O2 sensor. Fix it and see.
Thank you for the reply.
But, the CEL is on and stays on all the time. That is for the one code that is for the bad O2 sensor. P0159. That is the only code that is present.
The ABS light never comes on at low speed. It comes on, the light flashes and chimes, then stays on for a stretch and repeats the annoying cycle the whole time I am moving at 55+ MPH on the highway. Drop down below 55, no ABS light no ABS chime. No ABS codes stored. My scanner does read ABS codes, but nothing there. My mechanics professional scanner also found no stored ABS codes to exist anywhere in the system.
There's no ABS codes because it is not an ABS problem, fix the O2 sensor and watch what happens.
MassHoe04
MassHoe04
Western MA
OK. Thank you. I will be replacing the O2 sensors on Bank 2.
Just confirming what you are saying... A bad O2 sensor can cause the separate ABS light (below the check engine light) and ABS alert chime to come on at high speed only, even though they are supposed to be monitoring completely separate systems?
Thanks again for your information.
MassHoe04
MassHoe04
Western MA
Did that same thing happen to you? Just wondering... I'd be thrilled, if I could resolve the ABS light/chime issue just b replacing a failing O2 sensor.
afpj
Since you have to fix the O2 sensors anyway (recommend always do in pairs), like swathdiver said, see what happens. These vehicles have quircky electrical issues. Still, think checking wheel speeds off the 4 sensors is an easy diagnostic as well. Let us know what you find
MassHoe04
MassHoe04
Western MA
OK. I should be getting to the O2 sensors on Bank 2 tomorrow. S2 is throwing the the code on that side, but I will replace the upstream S1 on that bank as well. I'll let you know.
I just switched over from an 05 Jeep Rubicon, so I am no stranger with vehicles having their own quirks (LOL)!
afpj
By pairs, I think most people generally mean both bank 1 and bank 2 postcat or bank 1 and bank 2 precat.
drdave81
Waterford, MI
I'm curious to know how you think the ABS light can be turned on by an O2 code? Doesn't sound right to me. Yes, I'd still get the O2 fixed, but they're mutually exclusive systems. A sensor monitoring the exhaust gasses is not going to make an anti-lock brake light come on.
What OP is describing sounds more like a wheel speed sensor issue. At higher speeds, it can no longer read wheel speed and kicks the light. Older non-OBD systems were not required to always store a code, depending on what fault was occurring. So if the fault is not active, there may not be a code. You could try driving above 55, with a scan tool connected. When the light comes on, see if there is a code then. If you have a scan tool with data read capability, you can also read wheel speeds, see if one is off from the others.
MassHoe04
MassHoe04
Western MA
Update:
I have no idea how an O2 sensor would do anything with the ABS light/chime activation, but... Here is what has happened since O2 sensor replacement...
As of last night, I have replaced the downstream O2 sensors on both sides and swapped the 20" rims (with 285/50 tires) for some stock 16" Silverado rims. They currently have 245/75 tires on there, but that is only to buy me time until I get some 265/75 all-terrains in a few months.
I cleared the P0159. Drove about 10 miles around town last night and another 30 on the highway this morning.
No CEL or codes. O2 sensors doing fine.
When on the highway this morning (55+ MPH), the ABS light/chime did not come on as soon as it did before. It was coming on within a mile after getting up to highway speed.
Today... When it did come on it was a quick one for a couple of seconds before it went off.
It only did the really quick light/chime only 4 times in 30 miles. Maybe the system is beginning to recalibrate itself? The majority of the half-hour drive, the ABS light was off and was quiet. I'll see what happens on the way home.
I did not have the chance to pull any of the ABS sensors to clean them or brush any corrosion off the hub yet.
I'll keep you posted on any further developments.
MassHoe04
MassHoe04
Western MA
Update:
Sunday 11/7...
ABS light and chime still flashing, staying on a while, turns off for brief stretches and the cycle repeats for as long as I am driving over 55 MPH. Get off the highway, driving local roads 30 - 45 MPH and everything is peaceful again.
New downstream O2 sensors cleared that code, which has remained off for two days.
I think at this point, I can rule out the possibility that the O2 sensors or the CEL code they created had anything to do with what the ABS light/chime is doing. Not related.
I am due for new brakes. I will start with replacing the front pads and rotors. I'll be removing the ABS sensors to clean them of any debris and will brush off any rust that may be on the hub. See if that does anything. If not, front ABS sensors are really pretty cheap. I may just buy new front sensors with my front brakes anyway. No sense in taking rotors off twice for $30-40 bucks. Not worth the added time...
MassHoe04
MassHoe04
Western MA
In what condition are the upstream O2 sensors?
Upstreams are working OK. No fault codes. Engine seems to be running nice and smooth. They are on my list to replace, but not until after I am done with brakes and resolving my ABS sensor. The chime dinging loudly every few seconds for a half-hour drive to work is driving me batty! Thankfully, the highway commute is only on weekends for my part-time job...
MassHoe04
MassHoe04
Western MA
Update:
Still haven't gotten to pulling ABS sensors and scrubbing the hubs. But...
Still getting "Tighten Gas Cap" message on the info. center.
ABS light/chimes continue on the highway above 55 MPH.
Get the occasional no crank, but that is likely the PassCode sensor on the ignition. Still starts after a couple turns of the key.
I'll get to replacing the part for that later.
Most recent weirdness involves the factory radio with SiriusXM/NAV display. I turned the key and the PassCode no-crank thing happened. When it did start, the Radio was now on SiriusXM channel 2.
Looks like I'll be checking the ground connections on my next day off (Friday).
Maybe the grounds have a hand in multiple conditions I am seeing.
I'll let you know this weekend, what happens.
your abs issue is most likely a wheel hub, it is a isolated system, not sure how @swathdiver associated it with a 02 sensor?
small chance cleaning the sensor will fix the issue, it is sometimes the case but is more common given the mileage that the wheel hub or hubs need to be replaced, usually when one goes the other is not far behind.
if you do have a scanner that can read live data then load up the abs sensor screen and watch for the erratic one at speed, that will be your bad one.
other potential issue's are, cracked solder on the abs module board but normally what happens then is the abs light will come on solid once you have hit a bump in the road after key on and will stay lit until key-off, then with key-on it will clear because it has contact again until you hit the next bump in the road.
a bad ground would do the same thing-throw a solid abs light, not a flickering one that then goes away while key-on still
MassHoe04
MassHoe04
Western MA
I have live data on my scanner, but it is a Zurich from Harbor Freight. I confirmed, I can't see anything on ABS wheel sensor signals.
well then the cheapest option is to 1 either try to clean them, and/or go buy 1 abs sensor and put it on the left or right side, drive it, if the abs message is gone you guessed correct the first time, if not swap the sensor to the other side, if that fixes it great, if not then you probably have a bad hub.
you can check the hubs for noise or play by jacking up the front so the wheels are off the ground.
grab the tire at 12 & 6 try and to wiggle it and see if it has play, then grab it 3 & 9 and see if it has excessive play (you will have some play at 3 & 9) because of the steering.
then spin the wheel and listen for any strange noise it should spin quiet.
if either side has any play or noise that would indicate a worn out hub.
it's not a catch all end all but usually by the time the abs is coming on the hub will show signs of wear.
MassHoe04
MassHoe04
Western MA
Thanks for the advice! I just bought it and my trusted mechanic didn't feel anything excessive in the front end. There was a tiny amount of play at the pitman, but not a lot. The inner tie rod did have excessive play and was replaced.
I have pads and rotors coming from Rock Auto in the next day or so. My plan is to pull the sensors, inspect, clean and install the new front brake rotors and pads. If if cleaning the sensors doesn't take care of it, I'll go for new hubs with sensors up front and see what that does. Thanks again. I'll know by sometime next week, what happened or was found on inspection.
BadDaddy2003
