Front seat removal
Mike706
Can anyone tell me how to unplug the connector under the seat to remove it
which connector? there is likely more than 1, before you do that be sure the battery is disconnected so you don't cause any codes to pop or toast a module or airbag
usually there is a safety catch so it can't come loose in it's own, once that is out then you can squeeze the tab and pull it apart
M
Mike706
The big yellow connector that Supplys power and air bag. Looks like the power distribution connector under the hood. This is a 2021 or 2022 Tahoe
looks like you have to slide the beige color part back towards the yellow part to get to the tab
RST Dana
OH
I have to ask why you be taking the seat out of a 21/22? It has to be under warranty.
CL2011
I have a 2011 Tahoe LT and 6 months ago I noticed when I move my seat too far back the airbag light came on and when I moved the seat back forward the light went out. Now it's finally staying on so I'm assuming from my video searches The Wire either popped out or broke but I can't visualize it when I stick my head under the seat and look down by the right track. Anyone know if there is a two-pin connector going to the passenger presence sensor near the right track or is there just one harness that's the big one on the bottom of the floor with the floor vent is. GM wants $125 for what they say is a two-pin wire connector for passenger presents sensor. But they will not tell me the GM number so I can cross reference it with other websites. And do you guys also recommend I disconnect the battery to take the driver seat out and repair that connector? My Hope was just to cut it back 2 inches take the new connector and use butt connectors or whatever and then snap it back on the presents sensor but I certainly don't want to blow any airbags. And again if somebody knows the GM part number for the passenger presence sensor female connector that goes on the sensor that would be great. I researched a connector company that gave me B84A2. I don't know if that's their number or if that's the GM OEM number
Please post your questions in the correct model year section; the responses there will be more on-point for your situation.
Durobans
