2005 Tahoe/Fuel filling problem
Tahoe97
We are now having difficulty actually filling the fuel tank in our 05 Tahoe. The fuel nozzle from the gas station (any gas station) continues to kick off when we have it locked to fill, even on the slowest setting. Even if we manually hold the handle and try to fill after a gallon or so it kicks off, acting like the tank is filled which it clearly is not. Our local GMC dealership changed out the purge valve which after picking it up today did NOT solve the problem. We are also getting an error message on the dash telling us to tighten the fuel cap. This all started about 10 days ago and it now takes forever to fill the tank, 1-2 gallons at a time.
Does anyone have any idea about what might be going on with this?
Thanks,
JHE
GMT800 2005 Tahoe Z71
Navy Supporting Member
I am assuming you have not dropped the tank or done any other tank work recently, except for the purge valve, correct? That entire evap system needs diagnosed by a qualified shop and inspect the fuel fill tube/hose for a restriction. Time to get dirty.
Bill 1960
Testing the Limits
One thing to check is if the vent line is plugged with accumulated dirt. I’m not as certain on your generation but on mine it’s a recurring problem. The vent is behind the fuel fill and the rear tire slings mud up there which aggregates and blocks the vent. Then I get slow filling and codes.
That said, it’s quite likely to need some new parts. I have read a lot of stories from people who went about replacing parts without testing and ending up basically replacing the entire system. I second the advice from @PNW VietVet and get a qualified shop with a good scan tool to diagnose it properly. They can operate all the individual components and observe the system pressures to determine exactly which part is at fault.
Tahoe97
Tahoe97
Yes, the tank has not been dropped and no other work has been done.
Tahoe97
Tahoe97
To me this seems like the logical culprit. Is it easy to visually see this vent behind the fuel fill?
Bill 1960
Testing the Limits
It is on the GMT 900 07-14 models. It’s just zip tied to the fuel filler hose. I’m not certain on yours.
I just reach up behind the wheel and pull it down. Most of the dirt falls in my face, the rest I clean off and tie it back up. One of these days I’ll relocate mine.
Are you sure that it was the purge valve that was changed? It's on the engine. On the other end the vent valve vents the charcoal canister at times, and if it's stuck closed the tank can't vent as fuel is added. When the truck is turned off, the vent valve should be open; it's near the back of the fuel tank. Does your receipt show a part number for said replaced valve? (You likely do not have a vent valve that has been moved; that seems to be on later models.)
Other than that, overfilling the tank can compromise the charcoal canister, and the charcoal can get into the evap lines, blocking venting. I wouldn't base a diagnosis on that but it happens a lot.
You need a Tech 2 and evap knowledge, or a good shop (as @PNW VietVet noted) experienced with these simple systems.
When I did my new fuel pump, during my build thread, I just went ahead and changed the entire evap system and used Genuine GM parts. That system can be a pain, as I have seen in many threads here, so I just said "to hell with it" and replaced it all with absolutely no problems.
rockola1971
Indiana (formerly IL)
THIS. I believe the evap solenoid and vent filter assembly for evap runs around $20-30 and is a quick changeout too. Just gotta lay on your back unless you have access to a lift. Assembly is bolted to Drivers Side Frame Rail near the rear axle.
Vent valve location on my '04, at center rear of truck, in front of the spare tire. Pic is with fuel tank removed, vent valve in red square.
Sam Harris
This… so many people “top off” to get their fuel fill to a round number, and have no idea they’re pumping fuel into the charcoal canister, causing a major headache down the road..! This would be my first guess, based on your description, sounds like the venting is plugged. And our GMT800 are not setup identically to the GMT900.. I don’t think the air vent is a common issue getting clogged up. It’s very common, however, for the evap lines to get clogged with gummed up / broken down charcoal, due to having fuel in the charcoal canister.
Tahoe97
Tahoe97
Great feedback, thanks. Our 05 Tahoe is back @ GMC and they will try to isolate the problem. Part # 12581282 was changed. We also get the "Tighten Fuel Cap" error message which seems unusual as it is tight and was replaced by GMC 1 yr ago on an earlier service. This message only appeared after we started having problems filing the tank.
The code sets the tighten gas cap msg since the pcm can't sense the evap test being able to draw a vacuum on the tank and the associated evap components. The purge valve (on the engine) you had replaced could have been stuck closed, not allowing the engine vacuum to be applied during the test. It's more likely that something else is either restricting the evap system somewhere, or something is sticking open and venting all the time. Or even that the fuel pressure sensor on the fuel pump is faulty. It's easy enough with a bidirectional scanner like a Tech 2 to test the evap system and determine which component(s) is/are at fault, if one knows how to read the data.
Your fuel filling problem screams blockage somewhere in the system, either a vent valve remaining closed all the time, or plugged charcoal canister or lines. Are you shutting off the truck when fueling?
This is one of several Wells videos that describe how the evap system works, and a bit of diagnosis. If you want to understand more about these simple evap systems I would recommend watching this and some of the other evap videos on the Wells YouTube site.
PNWYukon
Olympia, WA
Thanks,
JHE
On my 2005 Tahoe I started getting the tighten gas cap message and occasionally the gas pumps at Safeway would kick off, but not at ARCO, but at Shell and not at Fred Meyer. I cleared the Gas Cap Code and it came right back.
I spent a few bucks on the easiest things first; Vapor Canister Purge Valve/Solenoid and a new gas cap. Problem Solved.
Tahoe97
Tahoe97
yes it does scream blockage. When we picked up the Tahoe after the purge valve was replaced we still say the Tighten Gas Cap message. It is back at GMC today for further diagnosis. I called them and alerted them to the smoking gun likely being a clogged charcoal canister and/or faulty solenoid vent valve. We'll see what they come back with. What ticks me off most is that they sent their tech to put $25 of gas in the Tahoe after they replaced the purge valve and the tech reported no issues putting the gas in which is B.S. because after we picked it up and saw the Tighten Fuel Cap message we went straight to the gas station and the nozzle kept shutting off and wouldn't stay filling.
Tahoe97
Tahoe97
Turns out the charcoal canister was filled with fuel so it was replaced as well as the valve solenoid. They credited me for the purge valve replacement so all 3 are now new. We'll know if this solved the issue when we fill up next. No more "Tighten Gas Cap" message so at least that is a positive.
BadDaddy2003
