Denali grill swap
Chuyito
Did it guys, it was more time consuming than I thought but definitely worth it.
Special thanks to hosseface for the direction and MelloYello95 for the instructions, turned out great.
Banks22
Michigan
CASTLEDFW15
North TX
Looks good. Was it a plug and play swap as in clips were in same location on both and lined up or some….’Trimmming” needed. If yours works then I might consider chancing the LT/RST/Z71 Grille swap after all. Price isn’t too bad but want to get labor estimate from Dealer to be safe.
C
Chuyito
Very much plug and play, same clips and all, the only thing that needs to be swapped is the camera, as the cameras sit different.
YukonDough
Where did you get your parts? Part numbers? I was thinking of ordering a full grille assembly for our Denali so we could have the grille blacked out and the shell/trim color matched. Then just swap out the factory unit once done and not lose our vehicle for a week.
C
Chuyito
Grill 84835783 $620ish
Camera. 84710888 $140ish
Top trim piece. 84341123 $140ish
I ordered everything off of gmpartsdirect, the illuminated emblem I ordered off of the gmc accessories website along with the puck lights. Best of luck bud hope this helped.
Durobans
