Fast Flash on right turn signal
davidbeaver1
Siler City, NC
Just recently, I had the right turn signal on my 05 LT start flashing fast. Knowing what that meant, I just replaced both the front and rear bulbs which seemed to solve the problem. Two days ago it started again on the right side. When i got out to see which light was out, they were all working! The fast flashing comes and goes with no real pattern and each time all the lights work just fine. Any idea what I should be looking for?
My initial guess, considering that you have already changed both bulbs with no solution, is that your BCM, which I believe controls your directional signals, is starting to fail. Other folks more knowledgeable than me on the 05 model will chime in, as perhaps it still has the legacy flasher plugin relay.
Hobert
Downers Grove, IL
I had a similar issue on my GM sedan 2002 Buick LeSabre. The problem was bad contact in the light sockets due to corrosion. Cleaned them out well with contact cleaner, some scrapping and used dielectric grease on the reinstall. All are still working for the last 4 years.
davidbeaver1
davidbeaver1
Siler City, NC
Thanks for all the help! I finally figured it out. The front Amber 4157 bulb was seated, but not making a solid connection in the plug itself. I cleaned and greased the plug and all is working again.
BadDaddy2003
