Leveled with bad tie rod angles
Mrobinson
Looking to correct tie rod angles is pitman/idler arm drop a option please help
imi4tth3w
not an option. you'll need a proper lift with aftermarket steering knuckle and lower control arm relocation brackets. most of these lifts are at least 4" of lift.
other solution is to de-crank your torsion bars and reduce the amount of lift you have in the front.
Mrobinson
Mrobinson
Problem corrected the opposite of what the lowered fix is,eliminated my bump steer
Bill 1960
Testing the Limits
Spacers under the tie rod ends?
Not in my garage. Steering linkage is already a weak point in the GM design.
Durobans
