5.3 starter issue, and parasitic battery drain.
xDan
So I've got a 2003 4x4 with a 5.3. lately I've had some battery drain problems. I connected my multimeter to test amperage draw. I turned on the interior light door disable switch but when either front door is opened or closed, for 20 seconds it will show 270 to 450 mA draw, then drops to a range of draw between 20mA (good) to 150mA. I've pulled about 30 different fuses, nothing has changed.
After putting all the fuses back in, the battery was charged but then the engine wouldn't turn over. Starter solenoid engages and I can hear the gear engage but no power to turn the engine over. I bought a new battery, had to charge it up because it was only 70%, same issue with starting as the old (6 years old) battery.
I decided to look at the starter and it's terminals. Terminals were pretty clean and dry but the solenoid and starter body were very oily and had caked on dirt so I decided to pull the starter. What a PITA that was, access to the electrical cables on the 4wd models requires removing the right wheel, ABS sensor wire plug, solenoid shield, the bloody oil dipstick tube!..and an air ratchet, because nothing else fits between the frame and inner wheel well. LOL. I got the starter degreased and cleaned up, I'll find out tomorrow if the SUV starts up or not.
If anyone has suggestions or experience tracking down odd parasitic draws on these things, I'm all ears.
I would recommend using the DVOM method instead of pulling fuses, since you don't want to be waking up modules when fuses are reinserted. Each standard fuse has two test points on it, and the fuse is left in place as the voltage drop is measured. Once the mV drop is measured, there are conversion charts online to convert to the mA draw value. If you need those charts and can't find them, say so and I'll post a link.
EDIT:
Here is where you can find the Voltage Drop Charts for multiple styles of fuses. Be sure to use the chart that matches the fuse package.
https://www.powerprobe-emea.com/ES/knowledge/fuse-voltage-drop-charts/
Here's a good video (and there are many others) about testing for parasitic draw:
EDIT: any aftermarket alarm or other device installed?
Some common sources of parasitic draw on these are (not in any particular order):
1. OE radio
2. Dash cluster (search for Chevy cluster silver migration)
3. Water in one of the PCM connectors
4. Driver's door latch
If you have the auto HVAC head, it can draw 60mA or so for 4 hours or more until it goes to sleep. Obviously there could be other sources, so let us know what you're finding after you get it running, and as your testing moves along.
xDan
xDan
Well.. I cleaned the starter and tested it, gear pops out and spins up, teeth in good shape. I inspected and tested the power cable to the starter, no connection to ground and has 0.5 ohms resistance to the battery. Battery terminals are also just fine. I pulled the fuses to the xenon headlights and the trailer power but with no ignition, just connecting a new, fully charged battery I'm now getting voltage across the battery drawing down to 10.8V, I connected my 100 amp jumper cables to a running vehicle and on cranking, I can hear the starter gear hitting the ring gear but that's all it does. Gauges aren't getting enough voltage to work properly either. For electrical testing I've got a DVM and tech 2.. Can't do the dvom method on the large fuses, there isn't access holes and I can't do that for long because the battery drain is so high now.
rockola1971
Indiana (formerly IL)
If im understanding your post correctly you are now working with a new fully charged battery (which new doesnt mean a good battery) and you are reading 10.8v across the battery while the starter is engaged? That is about what a starter that is cranking down to (10.8v). While parasitic draw is a common problem on C and K chassis. A problem that can happen even when the starter is NOT being cranked is the solenoid which is just a high current rated switch/relay contact could have its contacts bridged with conductive material from the contacts. This is caused by wear and tear by arcing as the contacts just close and just open up. This conductive material doesnt provide enough current flow to spin the starter over but is enough to give your starter some power which it will gladly take as a load and run the battery down. The solenoid could be junk.
The ground between engine block and firewall is a common one to break or corrode and cause the BCM to act a fool and not goto sleep which drains the battery down.
xDan
xDan
Without the key even in the ignition, voltage is dropping as if something like the starter is loading it. Because I don't have that inverted torx for the solenoid removal, I brought the starter to a local shop this morning. The ground to the engine block looks solid if a little oily. I'll give that a clean and reinstall.
xDan
xDan
I left the battery disconnected after a full 10 amp recharge over night, if it's voltage is below 12.85, I'm returning it.
rockola1971
And if the solenoid is bridged by carbon material from arcing it could very be draining the battery down. There could also be an internal shorted cell draining the battery down. Battery charged overnight should read around 12.86v +. If it dont then the battery is bad. (after checking output voltage of charger).
xDan
xDan
The battery left for two days settles in at 12.7V. it's probably fine. The one I removed drops to 12.5V after a day... Probably on its way out.
I had the starter solenoid replaced by a starter and alternator shop, but the original didn't have a problem engaging the starter motor contacts and the motor only had some minor surface rust on the inside of the housing and on the stator which the shop cleaned up. The brushes are in great shape. I checked for a seized engine but it turns easily enough.
Switching to acc, with IGN A 40A and IGN B 40A in, battery voltage drops from 12.45V to 12.25V.
Switching to run, it drops to 8.75V then increases to 9.6V.
Pulling IGN B 40A: drops to 10V on acc and run.
Pulling IGN A 40A: drops to 10.5V on acc, and 8.75V on run.
This initial voltage drop recovers over time when the key is left in run. If I put it in run then attempt to crank, the starter solenoid engages but there isn't power to crank the engine.
With the key left in run position and low headlamp relay removed as well as front, both rear marker and brake light fuses removed, (to prevent exterior lights from drawing power when ignition power drops) with main ign fuses back in, it's voltage drop across fuses are the following:
PCM: 0.001 15A fuse
0.218A
SIR: 0.045 15A fuse
9.83A
TBC IGN 1: 0.050 10A fuse
6.74A
RADIO: 0.003 15A fuse
0.655A
INFO: 0.003 15A fuse
0.655A
RADIO AMP: 0.005 30A fuse
2.70A
SBA: 0.040 15A fuse
8.73A
O2B: 0.060 15A fuse
13.10A
O2A: 0.053 15A fuse
11.57A
Improper voltage probe technique makes all this bad data.
xDan
xDan
I'll have to see. I don't have electrical probes that get to the mini fuses well, so I've been using some 0.040 lockwire, making sure I'm not touching one lead. What works well for probing those fuses? It's not the most consistent dmm at 2Vdc setting, waving the leads around causes voltage spikes.
Which circuit powers the fuel pump? I might jump the starter when I get a chance... Just to disprove that as an issue. Also besides the engine ground wire, where is the engine grounded to the frame?
Just standard voltmeter leads, probing the two test points on top of each fuse:
xDan
xDan
Wow. I've never noticed those, ever. They are on regular blade, m-axi fuses too. I've got a chart but it doesn't have glass tube fuses. I've rarely needed to check voltage drop over multiple circuits before so I've only been watching battery voltage drop and amperage bridging with fuse pulling. With modern stuff and their complexity, fuse pulling doesn't work so well.
Ok, why is m-axi censored?
xDan
xDan
I did a lot more circuit testing today.
With the battery charged at 12.8V, only a couple circuits were drawing power:
SUV locked, unarmed, no key in:
Engine compartment fuses:
IPC/DIC (10A)= 2.0mV= 270mA
Radio (15A)= 0,1mV= 22mA
No instrument panel fuses or anything else was drawing power. The battery is still draining down to dead within two days.
I also was able to turn over the engine with the starter (it was refusing at first, but I short circuited it with a large wrench through the wheel well. At first the new solenoid did nothing, then after hitting it with power enough times it engaged the gear, then started to turn over the engine decently well, not great but enough.) I started it by jumping with another vehicle using the key after that. It ran well, alternator charging at 14.35V. I tested the hell out of everything you can turn on. While running with the alternator charging away, nothing misbehaves and the engine idles fine. Every interior light works, HVAC is 100%, instrument panel, radio, subwoofer, locks, windows, mirrors, seat, rearview mirror crap, 4WD controller, wipers, washers, electric defroster, 7-way trailer plug, all the exterior lights work.
On to the circuit draws:
IGN A (40A)=1.2mV =316mA
IGN B (40A)=3.2mV =842mA
LBEC 1 (50A)=1.5mV =625mA
LBEC 2 (50A)=0.1mV =42mA
Blower (40A) OFF=0mV, 5=16.7mV =4.47A
HI-HDLP-LT (10A) OFF=0.1mV, =13mA ON=53.6mV =7.28A
HI-HDLP-RT (10A) OFF=0.1mV, =13mA ON=54.6mV =7.41A
LO-HDLP-LT (10A)=2mV (controller power used as signal for xenon low beams) =270mA
LO-HDLP-RT (10A)=0mV
FRT-PARK (10A)=11.9mV =1.62A
RR-PARK (10A)=2.4mV =323mA
LR-PARK (10A)=2.5mV =337mA
PCM (15A)=4.8mV =1.048A
PCM B (20A)=16.7mV =5.30A
FOG LAMPS (15A)=28.3mV =6.11A
ETC/ECM (15A)=0.7-1.3mV =153mA to 284mA
INJ 1 (15A)=0.9-1.1mV =197mA to 240mA
INJ 2 (15A)=0.8-1.1mV =175mA to 240mA
O2A (15A)=6.5mV =1.419A
O2B (15A)=6.5mV =1.419A
B/U LAMP (20A)=0.5mV =156mA
BTSI (10A)=1.3mV =175mA
IPC/DIC (10A)=3.5mV =472mA
HVAC/ECAS (10A)=0.6mV =81mA
SIR (15A)=1.9mV =415mA
RADIO (15A)=3.2mV =699mA
TREC (30A)=0.1mV =54mA
Instrument Panel fuses:
DMM (15A)=1.1mV =240mA
IGN 0 (10A)=7.3mV =984mA
IGN 3 (10A)=0.8mV =108mA
HTR/AC (30A) 0=0.0, 1=4.4, 2=8.2, 3=13.8, 4=21.0, 5=0.2mV =0mA =2.378A =4.432A =7.57A =11.35A =108mA
HVAC 1 (10A)=1.1mV =148mA
BRAKE (10A)=0.8mV =108mA
PDM (10A)=2.7mV =364mA
TBC 2A (15A)=10.6mV =2.40A
TBC 2B (15A)=12.2mV =2.62A
Any fuses not listed had no draw. My DMM on 200mVDC is sensitive to 0.1mV, +/- 0.05mV.
I then turned the SUV off, key out and left it unlocked:
TBC BATT (10A)=0.9mV =121mA
RADIO (15A)=0.1mV =13mA
I don't know what half those circuits power exactly and nothing jumps out at me as abnormal but if anyone with more knowledge about it sees something way off, let me know. The slower starter is bothering me but the main power wire at contact points and everywhere I can see it looks to be in good shape from battery, through the breakout box to starter. Something is drawing down an insane amount of power when the engine is not yet running, it always takes two batteries and a running alternator to get it to start. Once it's turning over, it fires up within half a rotation. It revs up fine with no hesitation as well, no codes present. Is there anything in the tech2 that could help?
bigdog9191999
sw michigan
i have ran into once before on a 2001 grand prix i had several years ago, had a draw that would kill the battery in a day or so. could not find the issue. checked fuses, to the point i started unplugging things under the dash and under the hood to try and isolate the issue, still died! the issue ended up being the fuse box itself! i had a couple extras laying around and it was the only thing i had not tried short of testing individual wires out the back of the box, but swapping the box fixed that issue. but i could not tell what or why. but something in that fuse box was messed up inside and allowed drain.
these can be very frustrating issues to find, good luck!
The key on, engine running values mean almost nothing when troubleshooting a parasitic draw. What matters is what is being drawn while the truck modules are supposed to be asleep.
The IPC/DIC is the Instrument Panel Cluster, and it's drawing too much while the truck is asleep. I think a previous poster mentioned the silver migration issue on the IPC and that could easily be the issue; it's very common. You could pull the cluster and disconnect it by pulling the connector, and re-testing to confirm whether or not the cluster itself is at fault for that 1/4 amp draw.
Do you have the auto HVAC control, where you can set the HVAC temp? Those can take 4+ hours to go to sleep, but it looks like your key off tests didn't show that as an issue. It would draw 50 or 60 mA until it goes night-night.
EDIT: the typical goal is to get the fully-asleep draw to be 50mA or less. My '04 runs consistently at about 27mA or less.
GMT800 2005 Tahoe Z71
Navy Supporting Member
It has been 15 years since I ran shops. At that time we used the 50 mA draw as a baseline. After I got out of that business I had heard that the new baseline was higher because of all the "keep alive memory" required for all the modules/computers on todays vehicles. I never heard what that higher baseline is or if it is higher.
I, too, have heard that newer vehicles would have a higher baseline for exactly that reason. I also think the newer year modules take longer to go to sleep. But thankfully not the case for the NBS.
xDan
xDan
Just putting the key in and switching to accessory is dropping voltage down to 9.5V, to run drops it down to 8.9V and to start it goes down to 5V.
I thought I found something to do with IGN B, but I insert the key and sometimes get a voltage drop from 12.6V to 10V but it's momentary drop.
briannorris
