15+ battery cable issues similar to previous generation?
Yukondoit2
Hey all. New to the forum, but not new to GMTs. My previous Yukon (08 6.2 AWD) had the notorious battery cable issue that plagued the entire electrical system. Is this a common theme with this newer generation as well? The truck is very sluggish to start (hot or cold) and apparently the infotainment screen flickered today on the wife. I'm relatively certain its ground/power cable issues like the previous gen, but was curious if this is common. Is it recommended to just replace with OEM cables or would anyone recommend going with a better quality cable. (welding cable?)
Tahoe14
Central Fl
OEM but price search, do not pay Dealer full retail price. Amazon, Ebay, Rockauto should be a good start.
Multnomah Falls
Military
Welcome to the forum from Oregon.
Many threads for many years of rigs with cable and ground problems.
Welcome to the Forum from NH.
Pics of the truck, please.
List the last 8 digits of your VIN number, and @915_Tahoe will give you the correct part numbers for the positive and negative battery cables, and then you can shop for price. Also, include GMPartsDirect.com in you parts vendor search, in addition to the above recommendations.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Hello, are you looking for the factory cables I can provide you the gm #'s. Just need the last 8 of your vin#
Motley07_Z71Tahoe
I need the factory cable numbers for my Tahoe, please. I have had the electrical issues that plague these vehicles and want to solve the issue. I also ordered a TCM because the truck just started doing the high rpm s between shifts of 1st and 2nd (I think). Tried the TCM reset and new filter / fluid - neither worked. Love my vehicle, hate the plagues. Last eight of my VIN : 7R415590
gat0r
DFW
havent really heard of Big3 update issue w/ this generation.
some have mentioned loose ground cable. another mentioned corrosion on a cable & dealer replaced it
could also need software update
but some others have mentioned HMI was issue
fozzi58
North Jersey
Cheap fix is to run a 4 gauge cable from the ground battery terminal to the body...somewhere on the firewall.
The better way is to take it to a car audio shop and have them replace the factory ground cable with a 2 gauge cable with gold connectors. Mine was carroded on the inside of the rubber sheathing.
Prospect62
Central NYS
I think I may be dealing with this issue now...seems to me that there are issues with grounding points inside the vehicle under the dash and then with the negative battery cable where it mounts to the frame area. Have seen reports of a few "bad cables" on K2 trucks but in my research, it looks like it's just the points where they mount to the truck (behind the front tire - how moronic) is what is causing issues by and large.
I'm going to unhook, clean up and reinstall my grounds and see what happens. Did you ever figure out your issue?
StuckinSoCal7
My wife got off work to have our 2015 GMC Yukon SLT alert that the Stabilitrak, Park Assist Off, Left front turn indicator failure. It drove fine from her work to home. I got it and ran ODB code check, there were many. I did some reading on the online forums and it said something about checking battery cable. About 1 month ago I change the battery, and maybe the connectors had corrosion that I missed, I change the battery at night with bad lighting. Sure Enough the Negative battery cable was the problem. I clean terminal and the cable connector, and tighten down real good.
Yes, NO MORE ERROR CODES or dash lights. The codes it was was shown are shown below. P2534 P0178 P0700 P1129 U112A B0AAA B2AA0
Screenshot_2023-12-29-17-18-23-68_0781a14d714be80de7524a3ea6aff3ac.jpgScreenshot_2023-12-29-17-18-27-96_0781a14d714be80de7524a3ea6aff3ac.jpg
meandmyhoe20
