Need Help misfire after replacing lifter
MalcDogg
Ok woke to the engine knocking put the scanner on it misfire cylinder 4
Took the valve cover off found out it the lifter was bad replaced the lifter look at the cam still in good shape put everything back together with new head gasket it started shaking hard misfire cylinder 4 moved the spark plug wires coil and injector cleared the code now I have a random misfire any ideas?
2008 Chevy Tahoe 5.3L
MalcDogg
MalcDogg
I replaced it with this one it was for cylinder 4 afm lifters and cylinders
It have a random misfire now change the head gasket on passenger side and intake gaskets
MalcDogg
MalcDogg
This is what I got for cylinder 4
wsteele
That is the right lifter from Melling.
A P0300 is a random/multiple misfire. What that means is more than one cylinder is misfiring, it doesn't necessarily mean they are random in nature.
The scan tool that you are using to see the codes likely will let you see the misfire counts for the various cylinders. Knowing which cylinders are misfiring and if it is say 4 and 6 misfiring (say the two you disturbed the wiring, injectors and coils on) or cylinders from both banks would be really helpful.
BG1988
make sure the spark plug wire did not get damaged sometimes pulling them out breaks them esp old wires or make sure it's pushed in all the way
rockola1971
Indiana (formerly IL)
Did you forget to plug an ignition coil wire harness back in? Possibly brittle wiring in the harness at a coil(s). Check each coil for spark. Not with your finger!
MalcDogg
MalcDogg
Ok so here’s an update
today I change the fuel injectors I notice the o rings was damaged and some of them was bend at the top so I changed them all I forgot to torque the head bolts so did that as well so
New head gasket
New injectors
New spark plugs
New wires
New intake gaskets
Got some white smoke coming out of tail pipe and now misfire cylinder 4 (pending) is back at idle it’s not as rough anymore drive fine other then the smoking
I’m at wits end at this point I don’t know what else to the harness on cylinder 4 do look bad I guess I can try to replace that but what’s up with the smoke now idk ‍♂️
MalcDogg
MalcDogg
Ok here’s an update:
I took everything apart and started over cleaned the heads checked the push rods and come to find out I didn’t torque the heads correctly I put everything back together with new bolts and torque them one of the intake gaskets was broken as well so everything is working fine for now thanks guys for all the info and help great forum to be apart of
Monkeywrench78382
2008 Chevy Tahoe/Yukon /Silverado LS engines. lifters are recommended to be replaced during head gasket service. Made this mistake my self a 450.00 dollar mistake when lifters are recompressed they stick w varnish and deposits when oil pressure is reapplied to lifters its not enough to unstick them and truck sounds like a tractor or outright knocking. Heads need to come back off and new lifters installed. You probably know this im gonna say it anyway soak new lifters 24hrs prior to install. I know you're not trying to hear this neither was I when I did a customers twice. No joy no joy at all.
BadDaddy2003
