160 thermo. Heat spike at 107° weather.
ROGELIO A GUZMAN
Los Angeles CA
So this weekend I went to las Vegas. I had 0 overheating issues in California weather. My Yukon stay well under 200 degree all the time here in Los Angeles weather. So I decided to drive to Hoover dam and it was 107. I did notice my temp go up to 203. Is it because the 160 thermo is not closing and keeps the coolant circulating? I did buy the OEM 187° thermostat last month but haven't installed it. If I swap for the 187 it should keep the coolant longer in the radiator right?
possibly, what made you decide to install a 160?
how old is you radiator?
typically heat issue's like that are because the radiator is not cooling properly and needs to be replaced
if the radiator was replaced did you use oem or some aftermarket? there is a restrictor valve on the oem radiators on the small line leading to the reservoir tank if there is not enough restriction then cooling does not work properly and coolant constantly flows bypassing the thermostat, some of the aftermarket radiators do not have the proper restriction.
afpj
203 is a heat issue? I idle at about 205 degrees in the high desert summer when the engine is fully warmed up. Freeway cruising it goes to about 197.
02 yuk, 4x4, 5.3 FF, stock. 206k miles. Original rad.
bigdog9191999
sw michigan
electric fans dont usually turn on till about 210-220. so think about that. and honestly going below about a 180 your not gaining anything and could actually be hurting mileage and such, esp if the pcm isnt tuned for it.
the thermo opens at the temp selected to allow the radiator to keep everything cooled off. once it opens thats as much cooling as you can get. so if your getting too hot then there is an issue with part of the cooling system. pump, rad, fans ect.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
I replaced not so long ago pump, fan clutch ,and OEM radiator. I did the 160 thermo thinking it would keep the coolant colder. It does when it's cool outside. But the 107° weather did make the coolant get a bit high. Well higher than normal.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
Oh ok. So 200° is kinda normal? I'm used to lower temps on my other cars. Lol
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
I'm new to the Yukon world , so I think I'm not used to seeing 200° temps on engines. From the other replies, 200° is kinda normal. I have a new pump, fan clutch ,OEM radiator. I think I'm going back to 187° OEM thermo. So that way the coolant stays skittle longer in the radiator and cools off some more. I also put a HD fan clutch so it pulls more air.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
At what temperature should I consider a over heating issue. Sorry for the dumb question but you guys have had Yukons longer that me.
ks03
Fool Excess Member
I wouldn’t call 220 overheating, but I don’t like to see it sustained there. 225 and I’d be concerned, and 230 I’d say something needs to change even in extreme conditions
203 doesn’t seem unusual for the conditions. In a perfect world a fan clutch would freewheel until it was needed like an electric fan. Gm put an electronic fan clutch on trailblazers and envoys to do that, which theoretically is probably the most efficient way to do it, but they had issues too
tRidiot
My understanding of the thermostat temp is when it opens to allow the coolant out of the engine block and into the radiator to be cooled off.
So a 160 thermostat will open sooner, allowing flow continuously above that point.
The 187 thermostat will allow the temp to be higher in the motor before opening. This is helpful in colder climates when you want your motor to warm up better/faster is my understanding.
Hotter outside temps won't change how these thermostats behave, and it won't allow your truck to cool better when the outside temp is hot with either one.
That's the way I understand it... the higher temp thermostat would allow your engine to run warmer before opening to cool it off - helpful in the winter to get more heat into the cab. This is what happened to me when I changed to a 187 themostat - then it stuck and I blew a head gasket. lol
HD_LS
Correct on all counts. And the theory repeated by many, about wanting to restrict flow rate through the radiator to give it more time in the radiator to cool, is complete BS. See the Tech tip #3 on the Stewart Water pump website: http://www.stewartwaterpumps.com/
For the OP, If you don't need better cab heating, leave the 160 in. You need a better radiator and or a fan that moves more air, to get the temps cooler.
Correct on all counts. And the theory exposed by many about wanting to restrict flow rate through the radiator to give it more time to cool is complete BS. See the Tech tip #3 on the Stewart Water pump website: http://www.stewartwaterpumps.com/
I think you may be confused with the restrictor used in these trucks, there is a small line that goes from the radiator to the coolant reservoir, if there is no flow restriction it just bypasses the thermostat and absolutely has a effect
HD_LS
Understood. I was referring the the OP's statement "Is it because the 160 thermo is not closing and keeps the coolant circulating? If I swap for the 187 it should keep the coolant longer in the radiator right?"
And yes the restrictor, since flow in that small hoses bypasses the thermostat, is required to get faster warmup, and more interior heat in the winter. However, if you wanted to really max out hot temp cooling, with an aftermarket radiator that did not have a restrictor in that small hose fitting: You could put a valve in that small hose path, to bypass the restriction for max raditor flow when you need max cooling.
for reference a good working system should show the temp go up to normal (usually either just before the middle mark or just past middle, or in the middle it can vary from cluster to cluster) and it should stay there and never move.
mine moved once while driving 95mph up a 6% grade at 9000 ft @75deg ambient for a extended period of time, it moved up to maybe 220-225 and after I let off for a bit it went back to normal
if your temperature gauge is moving at stop lights or heavy traffic or idling with the ac going then something needs to be addressed, it shouldn't matter if it's 120deg outside.
usually it's the radiator or the radiator has crap in the fins bugs/dirt/leaves, etc. the typical lifespan of a radiator is 5 years.
I flush mine annually and run citric acid thru it in the process (radiator flush) this keeps the system healthy
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
whats the highest u seen your temp go up?
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
With the 16o thermo my Yukon is normally at 170-180. so when I saw the temp rise I kinda panic. but from what I hear, 200-220 is pretty normal operating temps. i bought the Yukon with a bad water pump leaking and a plugged-up china replacement radiator. also, the clutch was bad. all replaced with OEM parts. I just thought it was a good idea to put a cooler thermo.
bigdog9191999
sw michigan
the only thing leaving a cooler thermostat in will do is take the engine longer to get up to correct operating temp, throwing off fuel tables and such until it does. most people dont realize it actually causes worse mileage in most cases, esp if the cooling system is working well and keeps the temp low as it will keep it cool enough the pcm will continue to try and compensate. if one was to keep the cooler stat having the pcm tuned to coincide with this is the only way to make it work mostly correct, and there still is no real benifit as they where designed to run a little warmer.
those of us in cold climates see as much fluctuation as anybody. when cold i can watch the gauge go up to temp, the stat open and temp comes back down, levels out when stat closes and starts climbing again. some vehicles do it more that others, but when you have a good large cooling system and alllllll that cold coolant is in there it can cycle enough back through the engine too close the stat and not have all the system coolant up to temp yet, and can take a few cycles to level out. but once it does it stays steady as it should, unless it is really really cold.
CrackerJack135
