160 thermo. Heat spike at 107° weather.
ROGELIO A GUZMAN
Los Angeles CA
So this weekend I went to las Vegas. I had 0 overheating issues in California weather. My Yukon stay well under 200 degree all the time here in Los Angeles weather. So I decided to drive to Hoover dam and it was 107. I did notice my temp go up to 203. Is it because the 160 thermo is not closing and keeps the coolant circulating? I did buy the OEM 187° thermostat last month but haven't installed it. If I swap for the 187 it should keep the coolant longer in the radiator right?
possibly, what made you decide to install a 160?
how old is you radiator?
typically heat issue's like that are because the radiator is not cooling properly and needs to be replaced
if the radiator was replaced did you use oem or some aftermarket? there is a restrictor valve on the oem radiators on the small line leading to the reservoir tank if there is not enough restriction then cooling does not work properly and coolant constantly flows bypassing the thermostat, some of the aftermarket radiators do not have the proper restriction.
afpj
203 is a heat issue? I idle at about 205 degrees in the high desert summer when the engine is fully warmed up. Freeway cruising it goes to about 197.
02 yuk, 4x4, 5.3 FF, stock. 206k miles. Original rad.
bigdog9191999
sw michigan
electric fans dont usually turn on till about 210-220. so think about that. and honestly going below about a 180 your not gaining anything and could actually be hurting mileage and such, esp if the pcm isnt tuned for it.
the thermo opens at the temp selected to allow the radiator to keep everything cooled off. once it opens thats as much cooling as you can get. so if your getting too hot then there is an issue with part of the cooling system. pump, rad, fans ect.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
I replaced not so long ago pump, fan clutch ,and OEM radiator. I did the 160 thermo thinking it would keep the coolant colder. It does when it's cool outside. But the 107° weather did make the coolant get a bit high. Well higher than normal.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
Oh ok. So 200° is kinda normal? I'm used to lower temps on my other cars. Lol
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
I'm new to the Yukon world , so I think I'm not used to seeing 200° temps on engines. From the other replies, 200° is kinda normal. I have a new pump, fan clutch ,OEM radiator. I think I'm going back to 187° OEM thermo. So that way the coolant stays skittle longer in the radiator and cools off some more. I also put a HD fan clutch so it pulls more air.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
At what temperature should I consider a over heating issue. Sorry for the dumb question but you guys have had Yukons longer that me.
ks03
Fool Excess Member
I wouldn’t call 220 overheating, but I don’t like to see it sustained there. 225 and I’d be concerned, and 230 I’d say something needs to change even in extreme conditions
203 doesn’t seem unusual for the conditions. In a perfect world a fan clutch would freewheel until it was needed like an electric fan. Gm put an electronic fan clutch on trailblazers and envoys to do that, which theoretically is probably the most efficient way to do it, but they had issues too
PascalBlues
