Scottydoggs
NJ
Pretty much what I did too. Yesterday I washed it, today I wiped it down with denatured alcohol ( I always have a gallon can of it plus some others like lacquer thinner) and applied the Cerakote. I was worried since I had painted mine 2-3 years ago and this stuff says it’s for unpainted plastic but it came out great. Oh and I vacuumed today too. Hope the Cerakote lasts on the painted plastic, we’ll see.
View attachment 280602 View attachment 280603 View attachment 280604 View attachment 280605 View attachment 280606
damn it, i didnt even think of doing the console trim. thats added to my list, thanks!
Stonefort
Did the rear sway bar bushings and link bushings. Energy Suspension - 35214R.
Not bad, needed a vice to press the new bushings into the links.
Ride quality is surprisingly better. Was not expecting that big of an improvement! My factory bushings didn't look bad at all. Might do the fronts here in a bit, possibly tomorrow.
Dantheman1540
Sugar Loaf Mountain
Really, really weak, but wtf.. my pos Chicom backup camera has been fading since installation. I really don’t see a need to replace it, or anything, so just used some model paint, to clean it up. We’ll see how long it lasts:
And, a milestone.. I was cringing for most of these 1k miles... :
Also put these cheap valve caps on the wheels a couple weeks ago. I like them. I know they won’t last long, but I thought they looked pretty decent:
Isn’t that cute. They even say GMC on them.!
Those wheels on your truck always make me want to find a set! Not sure if it's the semi aggressive sidewall or how clean you keep them but they look great.
blueinkd
Installing mine today and I already have the front kit on. I noticed a huge difference with the fronts on as well
Scottydoggs
NJ
slapped the drag radials on the SS today, did a few hits with the 2 step. spun em up way to easy. ive never spun these tires before lol
so the 2 step i have is a launch control, so i can use it to retard timing and then set it to come right back, or delay the ramp in rate. this was the least spin i was able to get, 7 degrees timing pulled, ramp in delay was over a few hundredths of a second. with a burn out and on a prepped track i think it should hook up.
blueinkd
That looks nice. After finally installing the full energy suspension Front/Rear sway bar bushings and new F/R sway bar links, I'd be shocked to find any real improvement with those +$400 bars. I spent maybe $100 and that's cause I bought new Moog rear sway bar links. I'm very pleased at the ride quality and overall stability of the steering. This might motivate me to install my 4 piston calipers.
Sam Harris
Oh... you don’t know..!
blueinkd
So it's that good of am improvement?? I'm sure it would be going from stock bars and stock bushings, which is probably the weakest link. The polyurethane bushings on the stock bars have made a huge difference and improvement on overall stability and body roll when changing lanes. I noticed taking the ramps on the freeways also very planted and predictable
Sam Harris
Yes, it is that good. I can’t compare to yours, since I didn’t do the same thing, but replacing the front and rear sway bars with the Hellwig kits made an absolutely dramatic difference. I’m absolutely floored at how well my 5800 lb Yukon corners, and handles overall. It’s like a different vehicle.
You don’t know because you haven’t upgraded your sway bars. Do that, then get back to us. I guarantee you’ll be surprised.
Keviebear86
I've been dormant for a while, but I'm here for asking another question. I am happy with my 3" lift currently, but my Tahoe is going to end up being a garage queen for a while with all the upcoming work. I want to debut it with a new look at the beginning of next year. I'm changing wheels, tires, retracting side steps, doing all the rust repair, and going higher on the lift. I am hoping to get some feedback from the guys that have 6" lifted Tahoes and what they like/don't like about their set up. Is there pros/cons to a certain brand of lift? Thanks for all the help so far! Definitely looking to keep everyone updated with pictures along the way.
wwiizz
