Looking for help with a part for 2012 suburban
DJBRIAN
This is the rear access panel of my truck it’s where you store jumper cables or something similar. The door is fine but both of the turn locks are busted. I can’t seem to find them anywhere. Can someone please help?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
Post the last 8 digits of your VIN number and hopefully @915_Tahoe will see it and look it all up. May have to get the complete panel.
Jason in DLH
Cheeseburger and Fries
MN
View attachment 276402 View attachment 276407 View attachment 276408
Here it is (#11 in diagram)...
https://www.gmpartsdirect.com/v-201...3l-v8-flex/body--interior-trim-quarter-panels
or directly here...
https://www.gmpartsdirect.com/oem-parts/gm-door-15838409?c=Zz1ib2R5JnM9aW50ZXJpb3ItdHJpbS1xdWFydGVyLXBhbmVscyZsPTIwJm49QXNzZW1ibGllcyBQYWdlJmE9Y2hldnJvbGV0Jm89c3VidXJiYW4tMTUwMCZ5PTIwMTImdD1sdCZlPTUtM2wtdjgtZmxleA==
Edit:
Oops...just noticed the only color they have in stock is Ebony (P/N 15838409).
So this won’t work!
That storage compartment is useless anyway it wont hold anything, maybe some paper, you are better off just using the space up on top where the jack is stored I keep all kinds of crap in there.
petethepug
Michael
SoCal
It should be the same part as the Yukon XL and looks identical to the black one in our old 08 Yuke XL.
Definitely not useless. That’s where you stow your emergency blanket + tarp, flashlight, gloves and copies of Ppwk for warranty on parts that have lifetime guarantees as well as the storage bag for your (filthy) flat tire after the spare is installed.
Whether or not you have to change the tire or crawl under the truck for some reason, you won’t regret having a blanket and tarp to put over snow/mud. Knowing you’ve got a powerful led flashlight to pack it all in a huge bag made just for spare tires and the muddy blanket and tarp can go in is a huge time saver.
If you’ve had to use the factory jack or just had to deal with stowing a flat, you know you want to bug out fast and with zero effort. I’m sure you also know how easy it is to get a new battery or water pump replaced on warranty while out of town if you have a copy of the original Ppwk.
Anyone ever try to orientate the factory jack back In its original position? It’s a joke and I promise it’s better to simply bag up all the jack parts and look it up online later. BTW, has anybody ever checked to see if your factory jack or wrench is actually stowed in that spot ... LOL!
Mine didn't come with any jacking tools so I bought them off ebay and yes, we take them out to drop the hoist twice a year and put them back where they belong.
avalonandl
Troy, MICH & Naples, FL
I orderd mine off of I think- it was about 24$.
Part NumberPart NamePriceQuantityTotal15838409Door - Driver's Side (LH)$9.181$9.18
Newgmparts.com
petethepug
Michael
SoCal
Ebony/ ivory or black/ white. Looks like the right color if the part # is correct.
That ABS plastic door panel goes to a normally empty storage area on XL & ESV. It’s held in by two tabs and two twist lock levers that let the door come off completely. It’s easy to lose if anyone at a dealership decides they need one to replace the one on their truck.
The jack, its three piece rod for turning the pump, lug wrench and wheel stops are under the recessed storage area like panel at the p/s 3rd row window sill.
brice715
