TPMS Sensors
Leevon
We charge around $100-120 each fdepending on the vehicle at my shop, that's dismounting the tire, installing the new sensor, re-balancing and programming. Lately we have been using Autel sensors with good results. Yes they're expensive...we're not a tire shop but we do quite a few and our price is comparable to dealers. There are some tire shops doing them for $75-80 though.
I second staying away from ebay and amazon. Rockauto is fine for sensors, problem is there will be a bunch of different ones cataloged, you need to make sure you're choosing the correct frequency.
bonegunner
I have been going to the wrong place for replacements @ $180.
I will shop price & brand next time.
That’s way too much money imo. I paid about $40 for each sensor and $15 each to install them. I don’t understand the need for demounting when all that’s needed is to break a bead, reach in and replace the sensor, and reinflate the tire. Don’t move it on the rim and you don’t need to balance it again. That’s what my tire shop did, I provided the sensors and they charged me $60. So $200 total.
Has anyone recently replaced? From my searches, it seems that OEM AC Delco is the way to go. Does anyone have other opinions? Where's the best place to purchase from?
Thanks
I put in OEM TPMS purchased from the GM store on my winter rims as I didn't want to screw it up, either. Purchased the $12 re-set tool on Amazon. Works great.
dnt1010
Tennessee
2009 Tahoe TMPS units replaced 2 years ago at Discount tire, pretty sure it was 60 bucks each. I was tired of the light coming on and incorrect readings. I have no idea what brand they put in, but they have lasted a couple of years so far. Sounds like the average life on the OEM units is around 8 to 9 years. Fingers crossed that these last that long too.
wsteele
That is what my local DT charges to replace TPMS. Not sure what brand they sell, pretty sure they aren’t OE, but the price is right and they stand behind the products they sell.
VDV18
VDV18
I was at my local Chevy dealer last Friday and their OEM's were $90 per. I was just shopping around though so didn't purchase, and they only had 3 in stock. Thanks for all of the info in here, good stuff.
wsteele
Just FYI. these guys carry OE stuff at much bette prices than the dealer. I am not a fan of these rubber stem sensors, but they are OE.
https://www.gmpartsdirect.com/search?search_str=TPMS
VDV18
VDV18
Update: I ended up deciding to have Discount Tire do them. They use Schrader (at least my local place) and were $60 per TPMS. The said the expectancy is 7-10 years and they have a 6 year manufacturers warranty. I have aftermarket 22" rims on a 2010 Denali and had them road force balance, along with 4 TPMS for $363 out the door. No more light, and I can just return to the shop if I have issues. Thanks for all the suggestions.
wsteele
Sounds like a solid choice.
oldchev
DIY preferred
Santa Maria, Ca
I have a 2004. Apparently this was a first year? or special that was different than other years that followed. The difference is the stem or the stem seal. I was doing tires at Costco and their brand TPMS didnt cover that year.
I was able to discover that Schrader makes the OEM TPMS valve most of the time for GM and I bought mine through TPMS.com.
They had the Schraders and cross checked what I needed. I think it was $115 for 4. maybe a little less. Got them in a couple days.
Costco put them on after the tire purchase because they couldn't get the ones I needed. Thanks Costco.
Durobans
