Replace light bulbs with LEDs!?
Nav792
Orlando, FL
So you used the vled resistor on the brake and reverse light and don't get any codes, correct?
I only needed 1 vled resistor for the reverse light. The turn signal led bulb worked without resistor. Haven’t tackled the brake light yet.
Bigmanny
Your gonna need resistors for the reverse light. I order vled resistor for $15. You only need to put it on the left side. Just about any Led bulb will work with it. I ordered auxito for $20 from Amazon. All good now
Where did you mount the resistor and by left you mean driver side?
Has anyone had success yet not getting error codes for reverse or brake lights?
I put LEDs throughout my 07 Yukon XL Denali, inside and outside, without any resistors, and I never received any error codes. I do have hyperflash, which I am perfectly OK with.
MonteJ
